Old 06-23-2017, 10:12 PM
LUKLA LUKLA is offline
Default Roll Servo question.
Folks, I am confused on dynon Roll servo connection with push rod!! Vans RV12.
Instruction said clearly
ATTACH ROD
END TO
THE MIDDLE
SERVO ARM.
I did follow the instruction and it doesn't seems align right.
When I check online lots of different blog and found every builder attached the rod in the last hole.
input will be appreciate.
thanks
Lukla.
Building Rv12 75% completed.
Old 06-23-2017, 10:47 PM
AJSWA AJSWA is offline
Default Roll servo pushrod connection
ATTACH ROD
END TO
THE MIDDLE
SERVO ARM.
thanks
Lukla.
The roll servo page 44A-03 instructs, ATTACH ROD END TO THE MIDDLE SERVO ARM hole. (Add the word hole to the sentence)
My Roll servo rod connection is defiantly in the middle servo arm hole.
Was it a late night or long day?
Cheers, Andrew.
Andrew
RV 120573
Old 06-23-2017, 11:37 PM
daveyator daveyator is offline
Trust the designers. They mean the middle hole on the servo arm. You can push the arm to whatever position you like, when everything is hooked up and calibrated, it will work as they planned it.
DaveH
Old 06-23-2017, 11:43 PM
Appreciated the input.
DaveH
