Old 06-22-2017, 11:09 PM
BruceP BruceP is offline
Default Glide Ratio?
What is everyone using as a glide ratio for their 9A's? Searching the threads I've sort of landed on 8:1 for the time being. I'm using the new Foreflight glide feature which is really great but I want to make sure I'm using the right number.
Bruce Peters
Bakersfield, CA
RV-9A, Flying 11/21/15
VAF#1145
Donation up to date 9/17
Old 06-22-2017, 11:15 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
8:1 sounds very low for the -9. That's closer to what the short-wing RV's get.
The Cafe Foundation report is probably the best place to start...
http://cafe.foundation/v2/pdf_cafe_apr/rv-9a.pdf
They measure it at about 12:1.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2019
Old 06-23-2017, 07:22 AM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
I use 12:1 in foreflight and it seems to be pretty accurate.
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Wings - Flaps/Ailerons
www.DarinAnderson.com
2018 donation sent!
Old 06-23-2017, 08:21 AM
ssturges ssturges is offline
The number I want to know is what is it going to be with a CS prop on an engine out? I don't want to every find that out the hard way.
Old 06-23-2017, 12:33 PM
Bevan Bevan is offline
There are so many airframe/engine/prop combinations. Further, in amateur built, no two are the same as in type-certificated aircraft. Therefore, the only way to know for sure for YOUR airplane is to go and test it. Then enter the data into your POH.
Bevan
RV7A Flying!
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 06-23-2017, 06:57 PM
Thank you. The link would not work, said I didn't have permission.
Bruce Peters
Bakersfield, CA
VAF#1145
Old 06-23-2017, 06:58 PM
Bevan
Everything about my 9A is nominally built to the plans. The only deviation is I have a Catto 3-blade fixed pitch prop.
Bruce Peters
Bakersfield, CA
VAF#1145
Old 06-23-2017, 07:35 PM
mikehoover's Avatar
mikehoover mikehoover is offline
Go to http://cafe.foundation/v2/main_home.php then click the "RESEARCH" tab, then on the right side menu click "CAFE APRs" and choose an aircraft.
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 06-23-2017, 08:15 PM
Great article with lots of good information. I did note that there was a range of glide ratios depending on airspeed from 9.5 to 12, and was 11 around the glide speed I have been using in my POH based on my own tests. I guess I should go out and repeat some of my testing to see if the results are similar. Anyway, thanks for the link.
Bruce Peters
Bakersfield, CA
VAF#1145
Old 06-23-2017, 09:28 PM
Steve Melton Steve Melton is online now
I use 10:1. Makes the calculation easy and gives a little margin.
1000 ft above x 10 = 10,000 ft or roughly 2 miles glide
2000 ft above x 10 = 20,000 ft or roughly 4 miles glide
or simply use the the number of thousand feet AGL x 2 = miles glide (does not consider wind, wind will affect the number)
any RV9 will be able to make this glide range
