Old 06-22-2017, 08:48 AM
Flyer2017 Flyer2017 is offline
Default Extending the gascolator drain thru the lower canopy
I bought a RV-9A built in 2003. (I'd love to build but don't have the time.) It is a great plane but has some squawks I'd like to fix. One squawk is that the gascolator drain is not extended below the cowling. It has been that way since it was built and means the drain only gets used at annuals! The previous owner said it was never a problem as there are drains on both wing roots.
The gascolator is mounted on the lower right firewall and if it was extended straight down it would have to pass thru the hinge material. It seems I need to bring it away from the firewall with a pair of 90 degree fittings and then down to exit forward of the hinge material. I'm concerned that the steel plumbing pipe necessary to do this will be unsupported and will vibrate in flight creating a possible problem. The drop needed is about 4 to 5 inches to exit the lower cowling. The alternative is to just bring it out past the hinge with two 90 degree fittings and reinstall the drain. Then I would make a hole in the cowling large enough to insert a fuel tester and attempt to hit the drain with the tester probe.
Thoughts? Thanks
Old 06-22-2017, 09:47 AM
terrye terrye is offline
Default Extending gascolator drain
Originally Posted by Flyer2017 View Post
One squawk is that the gascolator drain is not extended below the canopy.
I think you mean engine cowling instead of canopy. Please edit.
Terry Edwards
RV-9A (Fuselage)
2017/2018 VAF Contribution Sent
Old 06-22-2017, 09:48 AM
Sam Buchanan's Avatar
hall monitor
Or...put a 45* fitting on the gascolator bowl, then reinstall the drain valve. A hole it the cowl would allow you to insert the fuel sampler. That is how the gascolator drain on my RV-6 is mounted.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 06-22-2017, 10:19 AM
I have an fuel screen between my gascolator and fuel selector so I only check my gascolator when I have the top cowl off. I place a cup below the gascolator, turn the pump on the drain into the cup. I've never found anything.
Old 06-22-2017, 11:09 AM
RV6_flyer's Avatar
Similar on my RV-6. Just a HOLE in the lower cowl that the sample cup fits through. I think the hole is about 1" in diameter. Keep in mind that you will get nothing out the gascolator drain if you do not have the boost pump and fuel turned ON.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 06-22-2017, 11:48 AM
jrs14855 jrs14855 is offline
Default Gascolator
The elegant solution is a Cessna gascolator with a cable attached to drain handle next to oil door. Many of the late Cessna singles have this. The Cessna gascolator is much more robust. Gets rid of the flimsy wire bowl retainer.
The firewall gascolator can also contribute to vapor lock. If your airplane is working ok this should not be an issue.
On any low wing airplane the tank drain is much more important than the gascolator.
Hypothetical: pour a quart of water in the right tank. let it settle and take a sample from the gascolator. You will need to drain a lot of liquid before you start to see water, probably something on the order of 1 to 2 full cups. WAY more than the capacity of any sample cup. Now lets say you took a normal sample from the gascolator but forgot to sample the tanks. All that water is still in there.
A hard gascolator drain protruding below the firewall is a recipe for disaster in an otherwise surviveable crash. The Cessna gascolator has a 1/4" aluminum tube at the bottom, attach a rubber or plastic hose to that and locate the gascolator so the bottom of the tube is slightly above the firewall.
Old 06-22-2017, 01:14 PM
az_gila's Avatar
az_gila az_gila is online now
Smile
If it's water you are checking for, I think that maybe because the lowest spot in the fuel system is at the tank drains.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-22-2017, 02:18 PM
mikehoover's Avatar
mikehoover mikehoover is offline
I installed the extension with brass pipe/fittings from Lowes. Secured with tie wraps. Funny I only check it at annual, but then I take the gascolator bowl off so the drain valve extension is in my opinion unnecessary. Vans apparently didn't think it was necessary. Here are a couple of pictures:
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 06-22-2017, 03:39 PM
I have found water in my tanks but nothing in the gascolator, so far.
Old 06-22-2017, 05:26 PM
YellowJacket RV9 YellowJacket RV9 is offline
My concern with anything that comes down to the level of the cowl is that it is subject to being ripped off, resulting in a spray of pressurized (if the aux pump is on) fuel at an innoppurtune time.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
