Old 06-18-2017, 06:25 AM
Adam W Adam W is offline
Default more ruddder pedal questions
Thank you for those answer everyone
Does anyone know roughly for far off firewall i would want to set the pastic bushing blocks for someone 5'4" tall i have made 4 settings starting at 3" off firewall and 1 inch increments from there
is it worth upgrading the Vans brake lines?
Adam Wachtel
Thornhill Ontario Canada
Building RV7 #70770
Wings done
Empanage done
QB Fuse under way
Vans Airforce Dues Paid
Flying Piper Supercub PA18 150
Flying Cessna 414A
Old 06-18-2017, 06:53 AM
Adam---I mounted mine so the aft pedal bar is 8.5 from the firewall. I'm 5'4" on a good day, and it seems to fit ok, but I dont have the seat foam here.
UH yep, I'm upgrading the brake hoses.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 06-18-2017, 07:39 AM
The stock hoses/lines work just fine. What benefit are you after?
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 06-18-2017, 04:15 PM
mcgaughy mcgaughy is offline
I wondered the same about the transparent plastic hoses.....the connection ends look like they would be more likely to leak than the traditional type of aircraft brake hose fittings.
Old 06-20-2017, 02:56 PM
Thanks for that
I'm aiming just to have solid function and no deficiency due to inferior parts. But if they work fine I'm not looking to throw money away
Adam Wachtel
Building RV7 #70770
Wings done
Empanage done
QB Fuse under way
Flying Cessna 414A
Old 06-20-2017, 03:15 PM
Raymo's Avatar
Raymo Raymo is offline
If you have the cash, install the TS Flightline brake lines and never have to spend hours under the panel replacing them in the future. My hangar mate just did this, along with rebuilding his master cylinders and says his brakes work much better then before.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
