Old 06-17-2017, 07:21 AM
Adam W Adam W is offline
Default Brake question
Hello all
I have just put together my brake rudder pedal assembly. After bolting in the Marco master cylinders I find the brake pedals not returning all the way to neutral. The hinge bolts are not binding. Is this something that will improve when the system has fluid in it? Is this why I see many have used an upgraded cylinder? Is it normal?
Just wondering before I bolt this assembly in the fuse and it's way harder to work on.
Also does it pay to replace the Vans plastic brake tubing with higher end braded lines?
Adam Wachtel
Thornhill Ontario Canada
Building RV7 #70770
Wings done
Empenage done
QB Fuse done
Finish kit underway
Vans Airforce Dues Paid
Flying Piper Supercub PA18 150
Flying Cessna 414A
Old 06-17-2017, 07:31 AM
BillL BillL is offline
Originally Posted by Adam W View Post
Hello all
They should return. Remove from the assy and determine if they are sticky. I used a little air pressure (less than 1 psi) to ensure mine returned. I did remove the rudder pedal assembly to replace the forward skin, so, it can be done. That is when I found the non return issue, long bolts completely fixed it. I have additional return springs and collars on hand just-in-case. Those pedals have to have ZERO friction or they will impede the master return.
BTW - You will learn to work under the panel. A barrier to things on the firewall sticking holes in your head (1/4" plywood), several pillows and you are fine, as long as you are flexible.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
33/40 hrs
Aerobatics DONE!!
2017 Dues Paid
Old 06-17-2017, 07:43 AM
DGlaeser DGlaeser is offline
Do a search for 'brake return springs'. A number of builders, including me, put return springs on the brake piston rod to solve that problem.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport & EIS4000, 300XL, SL30, ADI Pilot II, PMA6000, AK950L, GT320
Old 06-17-2017, 09:40 AM
JonJay's Avatar
JonJay JonJay is offline
You should resolve the binding issue before resorting to springs. Binding means wear and tear on bolts and weldments. If you still want the springs as a backup, fine, but the internal springs are adequate (barely) when the system is installed and bolts aligned properly.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 06-17-2017, 12:04 PM
Default Yes.
We see this far to much. The Matco master cylinders work well if they can return to the top every time. If not there will be a slight back pressure on the system and the brakes will drag a little. These cylinders have a return spring in them that pushes up on the plunger, if the plunger gets to the top of the cylinder the poppet valve will open and be ready for the next push down.
What we have done to get these pistons to return all the way back to the top is install the same return spring that is inside the cylinder also on the outside around the rod of the plunger. It is a nice fix that works very well. You buy the rebuild kit from Van's, put the new spring that comes in that kit inside the cylinder, take the old spring, put it around the shank of a drill bit that is 1/64" bigger than the rod " 3/8" "and peen it with a small hammer, while rolling it on a steal plate or anvil. This opens the spring up a little tell it slides over the rod nice and easy. Then put a thick nylon washer at the bottom under that spring and a 3/8" caller with a set screw in it at the top of the spring, slid down over the rod. You don't have to press it down to hard, just enough to get it moving back to the top each time. I think our set screws were locked down about an inch or inch and a half down from the top of the rod to get it to work. This also makes the brake pedal feel much better out on the move. Just what we have found that works for us.
Yours, R.E.A. III #80888
Old 06-17-2017, 12:40 PM
snopercod's Avatar
snopercod snopercod is online now
The old-style matco master cylinders (old, as in 20 years ago) with the internal reservoir would stick like that and cause the brakes to drag (ask me how I know). I replaced them with the latest version and haven't had any problem since then.
(2018 dues paid)
Old 06-18-2017, 12:48 AM
gasman gasman is offline
Any hardware store will have springs, collar and nylon washer
that will fit.... Take some measurements and go shopping. It will cost you less than $5 for all needed parts.
VAF #897
2017 =VAF= Dues PAID
Old 06-18-2017, 04:56 AM
Default A couple more questions re brake rudder pedal
Thank you for those answer everyone
Does anyone know roughly for far off firewall i would want to set the pastic bushing blocks for someone 5'4" tall i have made 4 settings starting at 3" off firewall and 1 inch increments from there
os it worth upgrading the Vans brake lines?
Adam Wachtel
Building RV7 #70770
Wings done
Empenage done
QB Fuse done
Finish kit underway
Flying Cessna 414A
Old 06-18-2017, 05:57 AM
snopercod's Avatar
Does anyone know roughly for far off firewall i would want to set the plastic bushing blocks?
On my Lancair, I drilled a series of holes in the "floorboards" and installed nutplates so the location of the plastic blocks could be moved.
(2018 dues paid)
Old 06-19-2017, 09:46 AM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
What I did was set the holes as far aft as I could (I'm about the same height as you) I'll adjust as needed when the time comes. Remember that another part of the equation is the length of the rudder cables. When the time comes you'll have that to use as well to get the angle that suits you.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
rvblog.thebrices.com
