Old 06-16-2017, 01:13 PM
RedneckRoyalty RedneckRoyalty is offline
Default Anyone with an RV6 in the Detroit, Toledo, Indianapolis, or Louisville Area?
Hi! I'm planning on buying an airplane next year and the RV-6 is on my short list. I know that I can fit in a -7 and -8, but the prices for used RV-6s are more in my budget.
Is there someone in the Detroit, Toledo, Indianapolis, or Louisville area that owns one and would be willing to let me try it on for size?
I normally fly out of the Pontiac airport, but travel regularly to Louisville, Kentucky and Indianapolis, Indiana.
Steve Watkins, ATP
Old 06-16-2017, 01:41 PM
ty1295 ty1295 is offline
Have a 9 project at Louisville, but as you probably know same at a 7 for size.
I have been in a 6 and although slightly smaller, wasn't much and if setup right wouldn't be noticed.
Jeff Scott
Proud to have flown with P. Wagstaff and some odd Russian.
RV9A #91247/#91434
Old 06-16-2017, 06:47 PM
titanhank's Avatar
titanhank titanhank is offline
The -6, -7 and -9 are identical in interior dimensions according to the spec pages on vans aircraft. The only diiference is the builder's leg length is fixed on the -6 and can be 3 1/2" longer on the others. It is all about how the interior is finished out. If you must have the other 3 inches, install the almost -14 mod on a well priced -6 and fly on.
Rv-6
0-320/160hp
Dual pmags
Catto 3-blade gen 3
Smoke system
Glass panel
Old 06-16-2017, 07:15 PM
That is good news..I really want an RV-8, but, my wife and budget like the -6 more...
Steve Watkins
Old 06-17-2017, 04:21 AM
terrykohler terrykohler is offline
Default They're All Around You
Go to the RV "White Pages" on this site. Do a lookup by model number. Each model is listed by state, with the owner and phone number also listed. You'll likely find several 6's at Pontiac, as well as at nearby Ray Twp. (57D). With a couple of phone calls, you might save yourself a lot of driving.
Terry, CFI
RV9A N323TP
Old 06-19-2017, 09:45 AM
Thanks! That should work!
Old 06-20-2017, 12:07 PM
kinger's Avatar
kinger kinger is offline
Mettal Airport in Canton Michigan has 4-5 RVs EAA Chapter 13
James King
