Old 06-13-2017, 10:36 PM
n38139's Avatar
n38139 n38139 is offline
Default I need an RV-8 Canopy
Thought I would see if anybody had an RV-8 Canopy. Mine has a crack in it behind the rear seat.
Steve
Old 06-14-2017, 08:08 AM
spatsch spatsch is offline
I don't have a canopy but I figured I point out that cracks can be fixed e.g.:
https://www.polyvance.com/pfxcanopy.php-1
in particular behind the rear seat (common) the crack won't be in anybody's field of vision so it's a purely cosmetic thing if you want to replace or fix it.
Oliver
Oliver Spatscheck
RV-8 & J-3
N-2EQ & NC-49762
http://www.spatscheck.com/oliver
Old 06-14-2017, 12:04 PM
n38139's Avatar
I really don't want to replace it, I will try the repair and see what happens
Steve
Old 06-14-2017, 01:28 PM
SgtZim SgtZim is offline
I have a spare, but not ready to give it up yet. I hope to have mine mounted by September and will offer the second for sale if you still want it then. I'm in Kentucky.
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 06-17-2017, 10:00 PM
n38139's Avatar
Please let me know if you decide to get rid of it.
thanks
Steve
Old 06-18-2017, 12:32 AM
SMO's Avatar
SMO SMO is offline
FYI Wentworth has a wrecked -8 that appears to have a good canopy, they are auctioning the salvage.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
Old 06-18-2017, 12:52 AM
SHIPCHIEF SHIPCHIEF is offline
Yeah mine did that too;
The canopy cracked straight up from the weld where the lower & upper tubes joined behind the rear seat. I fixed it with some German product, which seems good, was clear and over-all might have held..but for the original stress riser and the fact that I couldn't add the repair material down into the Sikaflex and the skirt area. The second time, the crack went straight up, almost to the top of the canopy.
I ended up cutting out the crack with a Norton disc, and extended the cut all the way across the top to the other side to prevent the crack from migrating somewhere else, then I Sikaflex'd a hand fit and carefully rolled Targa Strip over it. Works great. Such a repair could keep you flying this summer, longer if it looks good.
I first saw the 'Targa Repair' on an RV-4.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
Old 06-18-2017, 12:56 PM
n38139's Avatar
Thanks for the idea's. I like the Targa Idea. Do you have a photo?
Steve
Old 06-22-2017, 03:28 PM
WingnutWick's Avatar
WingnutWick WingnutWick is offline
I have the same darn crack. I stop drilled it and have been flying with it for quite some time. Purely cosmetic at this time though I'd like it fixed at some point. It seems like this is a real problem with the 8's canopies. One day I guess I'll try to replace the canopy. The previous owner had the same thing and actually got insurance to fix it!!
Anyone know of any solid canopy guys on the west coast?
-Wingnut
Rhino driver by trade
RV-8 O-360
