Old 05-30-2017, 08:39 AM
olegusan olegusan is offline
Default More Arduino avionics
It is great to see experimental aviation going beyond rivets!
Here is the stuff I've been working on if anyone interested
Arduino based EFIS: http://experimentalavionics.com/efis-19264-ver-1-2/
Some video here: https://youtu.be/emqc_vi7-Rg
... and here: https://youtu.be/oVMNnUio5Sg
EMS: http://experimentalavionics.com/engi...gement-system/
Oleg
Oleg
RV12 # 877
Melbourne, Australia
Build log:www.RV12.com.au
My DIY Avionics: ExperimentalAvionics.com
Old 05-30-2017, 09:11 AM
I am by no means a software guy, and it's been a few years since I last messed very much with hardware. Seems these microcontrollers have really leapt forward in both their capacities and their reliability.
I'm running an AF2500 engine monitor and would really like to be able to capture its data on an SD card. Since I'm hoping for first engine run sometime soon (soon, in aviation terms, means this year, maybe... LoL), I'd like to be able to capture data from first engine start, but don't want the labor of messing with product development to get in the way of the labor needed to get ready for that first engine start.
Verns "packaged" product looks like a good idea. Now if only I could figure out how to use pre-developed code (like Brantel's serial data logger code) to load on the board.
Or maybe there is already a pre-packaged data logger available that would suit this purpose?
Old 05-30-2017, 10:20 AM
petersb petersb is offline
Oleg
Oleg,
Love it, is there anyway to wifi to the display screen. Thinking of the new iLevel BOM system where all the sensors etc are in a wing mounted unit and info is wifi'd to the in cabin display
Peter
RV7A New Dec 2013 - 360, C/S, slider
RV6 - 1600 Hours ---- Sold
Old 05-30-2017, 03:14 PM
vlittle's Avatar
vlittle vlittle is offline
Default Falcon-AVR group buy
I'm organizing an order for the Falcon-AVR final version pcbs. These are 4-layer boards and I'd like to get 20 boards ordered and in the hands of Arduino fans within a month. http://vx-aviation.com/documents/Falcon-AVR/
I already have three people signed up for blank boards. If anyone else is interested, please send me a PM.
Thanks, Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 in the oven
Old 05-30-2017, 03:32 PM
rzbill's Avatar
rzbill rzbill is offline
Originally Posted by vlittle View Post
In fact, most of the avionics devices I have designed have most of the cost and circuit board area devoted to protecting the device from the environment.
So true. Some time ago, I designed a logic circuit for a custom motorcycle instrument panel. It was flakey to the point of uselessness. Finally called my dad for help because he was skilled in the art. Turned out all my logic was correct but I did not have all the "protections" in place to make it a robust device. It was a learning experience. Success happened after his help.
Nice work BTW.
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 690hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 05-30-2017, 09:14 PM
vlittle's Avatar
Nice work BTW.
Very early in my career, I worked for a telecom company and we had to deal with residual lightning strikes, 600 V power line crossings and ESD.
Here is a design I did in 1982. All of the stuff in the foreground are environmental protection. I did the all of the card design, thick film hybrid design, some of the chip design and we used new fangled devices call PALs (ref 'Soul of a New Machine'). We were the largest consumer of surface mount devices in North America.
Yup, 1982... sigh. BTW it's an 8-channel LS/GS trunk interface card... you can still buy them today.
V
V e r n. ====
RV-9A complete
S-21 in the oven
Old 05-31-2017, 12:02 PM
joedallas's Avatar
joedallas joedallas is offline
Default Pixel C tablet with Garmin Pilot
Has anyone used a Pixel C tablet with Garmin Pilot.
I would like to use it for the right screen and the size is perfect.
Joe Dallas
Originally Posted by joedallas View Post
Experimenting with the Arduino microcontroller to perform some small tasks in the Aircraft.
http://joesrv12.com/Builder%20Log/bl_42_11.htm
Has anyone used this in a their aircraft.
Joe dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 06-05-2017, 04:53 PM
vlittle's Avatar
Thanks, Vern
A few folks have asked me about component costs for the Falcon-AVR.
Here's a breakdown of the options:
28 Volt, field configuration (includes case, primary input protection, etc.) $68
14 Volt, field configuration (includes case, primary input protection, etc.) $57
28 Volt, lab configuration (no case, only secondary input protection) $52
14 Volt, lab configuration (no case, only secondary input protection) $40
I would recommend starting with the lab configurations, then adding components as required by the application to get to a customized field configuration.
The costs were derived from Digikey's low volume pricing. Careful shoppers and those who buy in quantities can probably reduce the cost by 50%.
I'm still trying to get a group together to share the cost of a pcb order. PM me if interested.
V e r n. ====
RV-9A complete
S-21 in the oven
Old 06-06-2017, 07:22 PM
vlittle's Avatar
Default Falcon-AVR demo program
Here's an example of a simple C program (Arduino sketch) that shows how easy it is to process Dynon or Garmin serial information using the Falcon-AVR here.
This program displays:
HDG
IAS
ALT
AOA
on a 20 x 4 LCD screen as a 'backseat' display. The ALT is corrected altitude using the barometric pressure setting.
It took about an hour to write, which is pretty good because 'C' is relatively new to me (... I remember FORTRAN...)! I cut it down from a 1600 line program (auto-trim controller) just to demonstrate the function.
I have a graphics display module that would be very cool to use for virtual instruments, but that's a different project!
V
V e r n. ====
RV-9A complete
S-21 in the oven
Old 06-06-2017, 09:51 PM
jliltd jliltd is offline
Gosh......
RV-3B
