Old 05-23-2017, 08:46 PM
Blain's Avatar
Blain Blain is offline
Default Safe margin of tread wear
Been spending most of my time shooting landings. Have tire wear to show for it.
Not sure how far to run these out before they become subseptible to puncture. Flying off good pavement but there is always the chance of sharp rocks, etc.
Do I wait until cord is showing? Haven't done that since high school.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2018(my reminder)
Old 05-23-2017, 08:52 PM
Dismount and flip over, remount and you are good for lots more landing pracitce.
Old 05-23-2017, 08:53 PM
Well, I would have flipped them a few hours back, to even out the wear. Now,
I'm not sure. Can't tell how thin the area is with no tread.
Old 05-23-2017, 09:11 PM
Blain's Avatar
Ah, but how much more?
That's my concern. No wear indicators.
Blain
R-22 sold.
N82 Sierra Tango
Old 05-23-2017, 09:16 PM
Infidel's Avatar
Infidel Infidel is offline
If both tires are wearing the same, which from what I can see is on the inside, I'd pull them both and remount to where the less tread side is on the outside. Still plenty of life left in that direction. Otherwise, I'd be ready to order new rubber.
RV-4 0320\D3G 160, Whirlwind 200GA 70".
Old 05-23-2017, 11:48 PM
Check with Vlad......he would consider these brand new
Old 05-24-2017, 04:09 AM
g zero g zero is offline
Default Tires
Good Year says when the tread grooves are no longer visible . The first set I took off had minimal tread left . I cut the tire on the band saw so I could see and measure how much rubber was left . My observation was Good Years recommendation is a good rule of thumb .
A set of tires cost about the same as a tank of fuel , puts it in perspective . Don't run out of either .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 05-24-2017, 05:45 AM
Jesse's Avatar
Jesse Jesse is offline
Most RV tires wear on the outboard side. I wait until the grooves are just about gone, then flip them and basically have a new set of tread to wear on. When that side is just about through the tread, I change them. The retreads have more rubber after the grooves are gone, so I wait until hey are completely gone on the retreads.
352-427-0285
jesse@saintaviation.com
Old 05-24-2017, 06:27 AM
Walt's Avatar
Walt Walt is online now
Honestly, stuff like this amazes me that it would even be posted, that you would even consider risking so much for so little is beyond me.
JUST REPLACE THE FREAKIN TIRES!
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 05-24-2017, 06:35 AM
Mel's Avatar
Mel Mel is offline
I have to mostly agree with Walt on this. Remember that "6-ply rating" does NOT mean the tire has 6 plys. I recommend replacing the tires when the tread is gone.
Rotate the tires when the tread gets low (still visible) on one side. When the tread is low on the second side, replace them.
You REALLY don't want to deal with a blow-out on landing.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
