Old 07-09-2017, 10:04 AM
wirejock's Avatar
wirejock wirejock is offline
Default Nut plates
Originally Posted by jcarne View Post
Draker would you suggest installing these before ribs? I am about to start rib deburring phase and wondering if I should install these now as I may be able to get a squeezer on them.
Jereme
I seem to remember the manual talks about when to install the nutplates. Seems like it's after the tank brackets are fit. Ribs are not an issue. The rivets are easy to buck.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 07-09-2017, 11:22 AM
Default Seem to recall
If I seem to recall, the nut plates on the spar need to be off to drill the tank brackets. Then they are installed. JMO
In addition these rivets for the nut plates are non structural so can be pretty ugly. Better to have ugly nutplate rivets than a damaged spar.
Thank you
John S
Fuselage started
Old 07-09-2017, 12:23 PM
jcarne's Avatar
jcarne jcarne is offline
Good call guys, I forgot about the drilling of the bracket that needs to be done so installing these now would be a no-no for sure!
Jereme Carne
PPL
RV-7A Emp. coming along
Working on Wings
Exempt but gladly paying!
Old 07-10-2017, 12:08 AM
Draker Draker is offline
John is correct. In fact I had one nutplate on before I realized my error. Need to drill the z bracket holes before installing the nutplates.
