Old 05-21-2017, 08:50 PM
Draker Draker is offline
Question Main spar: Which nutplates go here?
Getting close to riveting my wing ribs to the spars, and I noticed some pre-drilled holes in the main spar near the root that look like they will house nutplates one day. I looked ahead in the plans and drawings, but so far did not find any reference to what these are for or when they go in. Seems like it might be easier to attach nutplates now, rather than after the wing walk ribs are riveted in, making it a tight fit. Or should I stop trying to think ahead so much? What are these for, and when are they supposed to go in?
Old 05-21-2017, 09:01 PM
RV74ME RV74ME is offline
K1000-3. Look at drawing 16a. Attaches to the fuel tank z bracket
Steve T.
N922WT (reserved)
KAUO (Auburn, AL)
RV-7 slow build
Tail kit COMPLETE
Wing kit COMPLETE
Fuselage kit IN PROGRESS
Old 05-21-2017, 09:09 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Fuel tank attachments. Detail A on page 16A on the RV-8 plans.
There are probably similar holes as you move outboard, although those nut plates attach to the forward side of the Z bracket in lieu of to the spar. Probably wouldn't hurt to install them now.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Whirlwind GA
www.mykitlog.com/dbro172/
1968 Mooney M20C - Sold
1956 C-182 - Sold
Old 05-21-2017, 09:57 PM
Ahh! thanks, yup there they are. I was confused because the spar was pre-punched for nutplates at only one of the attach points. Pretty clear upon further study that, for the others, they go on the brackets instead.
I will follow the ordering in Van's instructions and wait until I start on the brackets. I don't want to back drill the bracket through nutplates if I don't have to.
Old 05-22-2017, 06:42 AM
Be sure to check this forum before you drill your Z brackets....some good ideas here that are improvements on the van's instructions. Here's one good thread:
http://www.vansairforce.com/communit...+tank+brackets
Steve T.
N922WT (reserved)
KAUO (Auburn, AL)
RV-7 slow build
Tail kit COMPLETE
Wing kit COMPLETE
Old 07-08-2017, 04:29 PM
Arghhh... I'm finally at the point where I'm riveting these nutplates onto the spar and boy are they a pain in the rear. Due to their awkward positioning, I can't actually see the shop head as I buck them, and they're ending up over-set. I've probably drilled each of them out a three times already, trying to get reasonably decent shop heads. Going through nutplates like there's no tomorrow.
Any tips or tricks on how to get these done? In order to ensure the nutplate fits well I'm leaving a bolt in place while I buck them, but it doesn't leave a lot of room for the mushroom set. Squeezer is obviously out of the question due to where these are on the spar.
Old 07-08-2017, 04:45 PM
blueflyer's Avatar
blueflyer blueflyer is online now
Originally Posted by Draker View Post
.....Any tips or tricks on how to get these done? ....
Maybe get yourself a practice piece of material, and practice riveting (and then drilling out) the platenuts on the practice piece. Once you have your air pressure and feel for how much its going to take to properly set the rivets, then go back to the spar.
Old 07-08-2017, 10:02 PM
These rivets are just holding the nutplate and keeping it from spinning when you attach the bolt. Dont overthink it.
Steve T.
N922WT (reserved)
KAUO (Auburn, AL)
RV-7 slow build
Tail kit COMPLETE
Wing kit COMPLETE
Old 07-08-2017, 10:39 PM
Yea just took my time and turned the rivet gun down a bit. They're passable now. Good experience for when I really get to the tougher rivets.
Old 07-09-2017, 10:38 AM
jcarne's Avatar
jcarne jcarne is offline
Draker would you suggest installing these before ribs? I am about to start rib deburring phase and wondering if I should install these now as I may be able to get a squeezer on them.
Jereme Carne
PPL
RV-7A Emp. coming along
Working on Wings
Exempt but gladly paying!
