Old 05-18-2017, 06:50 PM
cczarnik cczarnik is offline
Just to add a little ... cutting the wheel is easy. A utility knife slices right through it. The wedges are double wide, you can split them and get two triangles. Screw the dremel mandrel in (I didn't even use a pilot hole). I shaped the cone by hand to rough shape on a bench grinder wheel. Then chucked it into the dremel and ran it against the wheel to final shape.
I am flying through rib prep now, IMHO this should be a sticky in tips- this is as big of a breakthrough as when I got my scotchbrite wheels.
Chuck
7a emp complete, wings underway
VAF Dues paid - 2017
Old 05-18-2017, 11:06 PM
KC10FE's Avatar
KC10FE KC10FE is offline
Default Thank you
I am extremely happy you all have found this useful. Thanks for all the wonderful comments. I hope all rv model builders benefit from this thread as well.....
Erik Lanning
Colorado Springs, CO
USAF, KC-10 Flight Engineer (RET)
RV-7A (Empennage in progress)
Old 07-05-2017, 12:41 AM
CubedRoot's Avatar
CubedRoot CubedRoot is online now
I gave this a shot tonight, and wasn't to happy with the results. After spending the time to cut and shape a cone, it lasted maybe 1 or 2 ribs, before I had to cut and shape another cone. I ended up with scotchbrite wheel dust EVERYWHERE and spent more time making the cones than I did getting anything done.
I am not sure I am using the right material. I have a bunch of these:
http://www.surplussales.com/Tools-Ac...abrasives.html
(The 5AFN part number).
They are pretty soft, and do great when I put them in my drill press to deburr the edges of the lightening holes.
Were my troubles due to using the wrong scotchbrite wheel to make the cones? Can someone that has used this method with success link me to the wheels you are using?
I am seriously considering going out and buying a 1" belt sander to get in these grooves.
Lynn Dixon
RV-7 Slider -
Tail kit Completed - March 2017
Wing Kit Started - June 2017
My Build Log: http://www.theskunkwerx.com
VAF Donation paid for 2017
Old 07-05-2017, 07:20 AM
Reflex Reflex is offline
I'm using this one with success:
http://www.cleavelandtool.com/3M-Cut.../#.WVzXEFGQy70
After cutting the wedge out using a bandsaw, I mount it in my Dremel and turn the Dremel on to a low speed. I then use the larger 6" Scotchbrite wheel on my grinder to shape the wedge. The wedge is turning the opposite direction of the wheel.
I've found that there is very little dust. In fact, I don't even need to wear a mask or clean up. The only thing that I have found is that I can't make the pieces last like KC
10 does. Even so, I find that this is a time saver and will continue to use.
Hope that helps!!
Fred
Dues Paid for 2018
RV-14
Working on Empennage
Old 07-05-2017, 05:06 PM
jcarne's Avatar
jcarne jcarne is offline
Lynn I have them same wheels, they are way too soft. I only use them for a last minute polish on things. You need the wheels that Fred mentioned, they are quite a bit harder and definitely do a better job at deburring (I use these first and then finish up with the softer ones). I will also add that this technique of making the cones didn't satisfy me entirely, unfortunately I still do the good ole flossing technique with 400 grit strips about 1/4" wide.
Jereme Carne
PPL
RV-7A Emp. coming along
Working on Wings
Exempt but gladly paying!
Old 07-05-2017, 05:48 PM
3M 03173 light rust stripper wheel. Avaliable on Amazon and in stock at the auto dept at Wally World. It's a mandrel mounted version of the ubiquitous maroon pad, slightly stiffer. Similar texture as soon as it's worn in.
Chuck it in the drill press and does wonders on the nooks and crannies. I use this on the outside and deburring cones on the inside corners where I can't get to them. Doesn't last forever but it's worth it.
With the combo my aileron ribs took about 15 minutes last night. Would have been hours with a file and sandpaper.
Chuck
Old 07-05-2017, 05:56 PM
CubedRoot's Avatar
Chuck,
Did you end up using one of those 03173 wheels to cut up and make the "deburring cones" for getting in the small grooves between the flange tabs?
I'm about to head out to home depot / Lowes / Ace / Wal-mart to see what I can come up with.
Lynn Dixon
RV-7 Slider -
Old 07-05-2017, 06:09 PM
Lynn- check PM
Chuck
Old 07-06-2017, 09:00 AM
tyconnell tyconnell is offline
I'm curious - I ordered and have used a Dremel 516 Abrasive Point, and I'm wondering if anyone has compared that attachment to what is produced using this method.
Ty Connell
Atlanta, GA
EAA Chapter 690
VAF dues paid monthly
ty.connell@gmail.com
N997TL reserved
RV-9(A?) empennage in progress
Old 07-06-2017, 11:03 PM
KC10FE's Avatar
Default Don't use Silicon carbide
Tyconnell........I can't remember where I heard it, but was told not to mix silicon carbide with aluminum. FYI.... maybe someone can confirm or correct!
Erik Lanning
