Old 04-27-2017, 03:43 PM
aparchment's Avatar
aparchment aparchment is offline
Default Wear time?
To the OP -- brilliant idea! How quickly do they wear. I am long past this point, but still curious for any remaining small area demurring.
Re the Cratex points, I used these too, but found that they wear really quickly.
Antony
RV-7A
Empenage complete, wings complete, tip-up canopy complete, starting wiring ...
Old 04-27-2017, 09:13 PM
KC10FE's Avatar
KC10FE KC10FE is offline
Default Scotchbrite DIY longevity!
I have had great success with this tool. The first pie piece lasted me both LH/RH Horizontal stab ribs, and still have enough to to the VS. I believe I can make 5-6 pieces per wheel, so one wheel should do all wing ribs as well. I think it is safe to say that I have saved at least 40% of time spent on rib deburring.......
Erik Lanning
Colorado Springs, CO
USAF, KC-10 Flight Engineer (RET)
RV-7A (Empennage in progress)
Old 04-28-2017, 04:29 AM
WVM WVM is offline
Talking
Thanks for sharing! Especially because I planned to do the wing ribs this weekend. Just in time!
RV9 #92188 - Working on wings
Old 04-28-2017, 06:45 AM
jcarne's Avatar
jcarne jcarne is offline
Erik how did you cut the pieces out? Did you just use a band saw? I ask because I have tried to cut these for a different reason and they are always tough on things.
Jereme Carne
PPL
RV-7A Emp. coming along
Working on Wings
Exempt but gladly paying!
Old 04-28-2017, 10:31 AM
KC10FE's Avatar
Default Cutting scotchbrite wheel
The best way I found to cut the wheel, was to change my bandsaw blade (which comes standard with all purpose blade) to a metal cutting blade. And then just two cuts to the center of the wheel....Wah La !
Erik Lanning
Old 04-28-2017, 03:52 PM
rv9builder rv9builder is offline
Cool idea, Erik! How did you shape the Scotch-Brite into a cone?
Thanks!
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
Old 04-28-2017, 04:43 PM
jcarne's Avatar
Awesome Erik thanks!
Jereme Carne
PPL
Working on Wings
Old 04-28-2017, 04:48 PM
jcarne's Avatar
Thanks!
I have shaped entire scotchbrite wheels (to get rid of grooves) by doing the following which will work in this case too. I put small wheel on die grinder (in this case it will be dremel) then take it to my rotating scotchbrite bench grinder wheel and shape the small one. I make sure they are spinning opposite directions of each other. This works extremely well but definitely make sure you are wearing eye and lung protection as a lot of dust flies! It also did not make any dent what so ever in the big scotchbrite wheel on the bench grinder so you don't have to worry about spending that $78 bucks again.
Jereme Carne
PPL
Working on Wings
Old 05-07-2017, 09:09 AM
Draker Draker is offline
Perfect timing. I just laid out all the wing ribs yesterday in advance of starting to prepare them, and I might try this method.
Old 05-07-2017, 07:34 PM
goatflieg's Avatar
This is indeed a great idea. Made my own right after seeing this thread, and using this technique a LOT for all the scalloped fuselage parts. I found the scotchbrite wheel easy to cut with a hacksaw and used the bench grinder and dremel to shape. I go through them fairly quickly... but definitely the right tool for the job.
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2018... extra payment included for psychological therapeutic services rendered.
_______________________
