Old 02-02-2017, 04:53 PM
rvtestpilot rvtestpilot is offline
Default My attempt at a carbon FWD baggage door
It's a good start. The idea is to have 1/4 turn fasteners on the lower corners instead of the key lock and monkey motion.
Noel Simmons
4063664638
Old 02-02-2017, 11:19 PM
greghughespdx greghughespdx is offline
Cool. Any more pics and details? Any special technique?
Building RV-8A as of September 2014 (N88VX reserved)
VAF build thread - Flickr project photo album - Project Facebook page
Flying a Warrior PA28-151 and a few RVs here and there
TeenFlight program mentor
Exempt, but paid anyhow
Hillsboro, Oregon (EAA 105)
Note: Opinions, information and comments posted by me on this site do not represent direction from or opinions of my employer.
Old 02-03-2017, 09:13 AM
Vacuum bagging might help with those bubbles and voids.
The general technique isn't hard. This shows the basic plan. The fabric and core are your part, the rest is the process:
Here's my vacuum pump and my plumbing:
The stub vertical pipe below the gauge is a trap.
I take the pvc pipe up to the part and put it under the outer bag. That section of pipe has several holes in it, and I lay some bleeder/breather mat under and over those. Here in Boulder we typically see about 12.5 psi of air and I can recover about 9 psi of vacuum with my simple and cheap set-up, so pvc is fine.
I use heavy but common plastic sheet for my outer bag and duct tape it down. That's adequate. The bleeder/breather mat is common padding from a fabric store, an inch or so thick. ACS sells the release film and the peel ply is polyester aircraft covering (the cheaper non-certified stuff). The pump came from McMaster and is rated for continuous use; I had it run for a week on my boat once to dewater a section of core. It was as good after that as before.
Old 02-03-2017, 08:12 PM
GHRoss3's Avatar
GHRoss3 GHRoss3 is offline
Default Carbon fiber Galvanic Corrosion & Aluminum
I'm surprised this hasn't already been brought up with this thread. Carbon fiber reinforced composites (CFRC) and aluminum causes galvanic corrosion.
Carbon Composites' Drawbacks
Despite all of the excellent properties of CFRCs, there are issues with using CFRC and metals together. Carbon fibers in CFRPs cause this material to become electrically conductive. The carbon fibers are electrically conductive and electrochemically very noble. Therefore, when a metal is electrically connected to a CFRP, it is more susceptible to galvanic corrosion. This situation becomes worse when a large surface area of carbon composite components is coupled to small metallic parts (such as fasteners, bolts and nuts). In these circumstances, the rate of galvanic corrosion is extremely high due to the high cathode to anode surface area ratio (Ac/Aa). . . Aluminum alloys are extremely vulnerable when they are coupled to a carbon composite.
This was copied from https://www.corrosionpedia.com/2/155...orced-polymers
Hopefully the composite master DanH will pipe in on how to isolate the carbon fiber from the aluminum.
Cheers
George
After Oshkosh '91, began dreaming of my RV-?
Tool kit in hand, May 12
Exempt but still renew VAF Dues each Dec
Old 02-03-2017, 10:40 PM
DanH's Avatar
DanH DanH is offline
Originally Posted by GHRoss3 View Post
...how to isolate the carbon fiber from the aluminum.
The usual approach is a ply of ordinary fiberglass to isolate the carbon. Alternate approach is two coats of epoxy primer and two coats of paint, then hope it doesn't wear though.
If aluminum rivets are used, they too must be isolated from the carbon somehow. Minimum is to wet-set in a moisture proof sealant. Proseal might do.
Good luck finding a titanium lock assembly.
This is not a great application for carbon.
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-05-2017, 11:13 AM
Default More picture
Did the bonding of the foam reinforcing yesterday. And it turned out really nice. The curve of the door needed to be slightly modified as my quick mold was slightly relaxed. But today the door fits really nice! I need to clean up some edges.
And let me add, there is fiberglass on the surface so the carbon won't corrode the aluminum that has been primed, painted, and clear coated.
And vacuum molding only works if you have a proper mold that will not deflect, inside curves require a very very strong mold!!
This particular door along with airplane will be wrapped
In conclusion: this is the "perfect" and proper size part to make a vacuum mold from. Any takers?
Old 02-05-2017, 11:16 AM
that is truly impressive.
Old 02-05-2017, 12:45 PM
Originally Posted by rvtestpilot View Post
....And vacuum molding only works if you have a proper mold that will not deflect, inside curves require a very very strong mold!! ....
Actually, they don't, if the part is sealed to the side (typically an extension of the side) that it's up against, and the back side is at ambient air pressure.
Old 02-05-2017, 02:09 PM
Chkaharyer99 Chkaharyer99 is offline
Does the carbon fiber door weigh less or more than the stock Vans baggage door? It looks really cool BTW.
Charlie
RV-8
Old 02-05-2017, 03:52 PM
I'm going for lighter. And I don't like the modified lock and pins of the stock door so just going with to 1/4 turn fasteners from sky bolt.
