POSTING RULES
Donate yearly (please).
Advertise in here!
Today's Posts
Insert Pics
11-13-2016, 09:06 AM
Keep looking
Paul,
I very much doubt that your CHT issue is baffle related.
I know you said the timing was "good" where is is set?
What is your take off fuel flow?
It needs to be 26GPH no less!
Certainly good advice on all the baffle and clearing the fins from casting flash
but your temps are ridiculously high for a stock installation.
As a comparison, I added a set of louvers on the bottom of the cowl, (2x
6 inch sections) and rarely, even on 100F days see temperature above 380 in climb and around 300 to 320 in cruise. In winter I have to tape those louvers off to keep CHTs from dropping below 300F.
I am north of you in the SF Bay area.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
11-13-2016, 03:52 PM
, +1 on what Ernst says. I see about the same temps in cruise as Ernst, in climb, as long as I keep the airspeed above 120kts, my temps stay below 400.
How many hours do you have on the engine? My temps did not come down until I had 20 or so hours. What is your timing? What is your FF rate? 24 to 26 is about normal.
Bill Peyton
RV-10 - 780 Hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
11-13-2016, 09:34 PM
Engine has 45 hours on it.
Timing is whatever it said in the manual - 23 or 25 BTDC with Slick mags. Can't remember off the top of my head but it was checked spot on 15 hours ago.
Mixture could be too lean from what you have said. My field has a density altitude of around 4-5000' so whilst it may be good for this, it could be too lean compared to sea level. I'll check the FF on my next TO but I believe it is around 23gph. I can see why this would affect the climb CHTs but if you lean to a fuel flow in the cruise, how does the max FF affect anything?
Thanks for the advice.
Paul
Mercy Air, White River FAWV
ZU-IIZ - "Zeus"
2017 Donation Made
11-17-2016, 04:14 AM
Paul,
Please note that quite a number of fuel control units in recent years are coming out of the factory at min fuel flow or worse. I suspect the old timers who built them knew they had to achieve MAX flow and set them up right. They will be retired and replaced by who knows what cheap labour. Just a hunch. But we have seen many in the last few years.
With a DA of 5000' approximately I would expect the flow to be in the 21.5GPH range. But that is a guess off the top of my head, but a pretty good one.
The cross check is simple, at full rich your EGT values assuming probes are about 2" from the flange, should be around 1280-1320dF. This is also dependent on the timing being right.
You should climb using the target EGT method, have a poke around the APS website, we have a download you can do which explains it.
I can climb in Australian summers at 120KIAS and not go past 380-385. Appropriately LOP and that is a variable, but at 10,000' that is 10-20dF LOP, and if you can get down to 9.3GPH it sounds like your GAMI spread is quite OK. Normal flow at that would be 10-10.3 GPH. Typical CHT in the cruise LOP would be 330-345 at this time of year (Summer) and 310-330 in winter.
______________________________
David Brown
The two best investments you can make, by any financial test, an EMS and APS!
11-17-2016, 09:26 AM
My current rv10 will climb full throttle, 90kts all day and never hit 400. Bone stock cowl, baffles, louvers. Gear slot extended maybe 2 1/2 inches. They should all do this. If one can't, then something is being missed.
Actual repeat offender.
11-17-2016, 12:08 PM
Lowering CHTs
Have you considered going lean of peak? Have you listened to or read this leaning article about the RED BOX? I fly my O-540 lean of peak which is way richer than any engine stumble. I use 6 temp probs so I can see what's happening. My plugs are always clean. Excess air can cool the temperatures.
http://www.eaavideo.org/video.aspx?v=2534345030001
Steve Lynn
RV-7A
90% Finished
Working on Wiring
Only panel left to go.
Anacortes, WA
www.mykitlog.com/sglynn
11-17-2016, 07:29 PM
Just a point of order. It is not excess air, for every intake at the same conditions there is the same amount of air, and there is no way physically possible for any "excess air" to do the cooling you get with LOP ops.
It is simple. Lower peak pressure in the cylinder caused by a greater ThetaPP angle. Nothing else.
As for the problems the thread starter is having, going LOP will lower his temperatures for sure, but he still is off the ball by a bit.
David Brown
11-17-2016, 11:53 PM
Thanks again for all the input.
TO fuel flow @ 5000DA is 22.5 so that sounds about right. Climb CHTs at 120kts are fine - just occasionally creeping over 400F on the rear cylinders but well below 435F.
Now I have finally got all my EGT probes working, I have found that LOP gives me considerably lower CHTs - around 370F on the rear cylinders @ 6000' and around 350C @ 10k. Bearing in mind it is summer here and the temperatures at 6000' are still around 25C, I can live with that.
So, I'm pretty happy now but will try the old "washer between cylinder and baffle" trick next time I have the lower cowl off.
Paul
ZU-IIZ - "Zeus"
2017 Donation Made
11-20-2016, 05:12 PM
Paul, on the weekend climbing through 4000-5000 I saw flow higher than that, I should have taken a photo.
I would try to get to a sea level port and do a takeoff there and see what flow you get passing 300'-600' when the numbers have settled down.
Should be around 25.5 GPH.
David Brown
11-21-2016, 12:24 AM
Might be a bit tricky around here - at least until I do a trip to Cape Town
In any case, surely that only affects the climb CHTs? If you lean to a fuel flow in the cruise then surely it makes no difference what the TO fuel flow is......
Paul
ZU-IIZ - "Zeus"
2017 Donation Made
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
