Old 05-14-2016, 05:58 PM
jbDC9 jbDC9 is offline
Man, y'all make this sound so complicated! In 1260-ish hours and lotsa oil changes I've never had help or a contraption to drop the lower cowling by myself. Screws at the bottom, pins on the sides; screws out, pull the pins, lower the cowling and pull forward with just two hands, easy peasy, no scratches.
John Bixby
RV-8 QB sn 82030 - 1475 hrs
O-360-A1D/CS/Pmags
New Waverly, TX
VAF donation Dec 2017
Old 05-14-2016, 07:08 PM
boom3's Avatar
boom3 boom3 is offline
I have a 7A and agree with John in the previous post. I do find it easiest to remove by myself. (Every time someone tries to help it just makes it harder.)
First I fold back and tape all the associated rubber baffling to keep it from catching anywhere. Then I stand on a chair in front and sort of lean over the spinner so I can spread the lower cowl in order to clear the side firewall hinges. Once the hinges are clear I just move it down (back low) until it clears the spinner. Then I just slide it out the front.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
Old 05-15-2016, 11:38 AM
Rupester Rupester is offline
I'm guessing that the tail-dragger guys who expound on how easy the lower cowl removal installation is, have likely never tried the same tasks on a nose-dragger. I've done both, and the latter is MUCH more challenging.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 06-30-2017, 02:51 PM
tturner tturner is offline
If you have Skybolt fasteners on the firewall then this method will work. I use copper clecos in the Skybolt fasteners.
Tommy Turner
Fayetteville GA
RV-4 flying
RV-6 flying
RV-8 Building
Old 06-30-2017, 08:39 PM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Works well
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Nov 30, 2017
