Old 10-20-2014, 12:19 PM
JHartline JHartline is offline
Default Section 7, revision 1
Guys,
Revision 1 to section 7 (rudder) has a change on page 07-11. In the added step 5 and Figure 1 it has you final drill #33 the aft-most 6 holes in R-903 - the rudder tip rib. The current holes which I have already final drilled and dimpled per the plans are #40 to match the skin and the rivet call outs on page 7-12, figure 2.
So...what gives? The rivet callout is for a 426AD-3-3 which is a little small for a #33 hole. What did all you smart people do here?
Also, what did you use to get inside the aft part of that tip rib to squeeze those rivets? That's a mighty tight fit!
James Hartline
Carrollton, GA 5GA2
RV-14 - Finish and FWF in progress
T-Bolt IO-390
Maule MX7-180
Old 10-20-2014, 12:25 PM
Default Read the posts!!
Answering my own post, but is the intent to use MK-319-BS rivets here? Then the skins will need to be #33 drilled to match the rib.
James Hartline
Carrollton, GA 5GA2
T-Bolt IO-390
Maule MX7-180
Old 10-20-2014, 12:39 PM
Yes, the #33 holes are for the installation of MK-319 rivets.
Scott McDaniels
Hubbard, Oregon
Old 10-20-2014, 07:19 PM
Default Thanks for the info
I appreciate your help - much learning in progress.
James Hartline
Carrollton, GA 5GA2
T-Bolt IO-390
Maule MX7-180
Old 06-26-2017, 10:55 AM
SabreFlyr SabreFlyr is offline
Default Reviving an old thread
Don't think I've seen this addressed: what dimple is used for these holes? I have a CS4 dimple set but that's a bit big.
Ray Dosh
LJ45 driver
RV-14 QB #140212
VS, rudder & elevators finished
HS started
2017 DUES PAID
Marion, IN MZZ
Old 06-26-2017, 12:47 PM
We use the MK-319 rivets to replace a AN426AD3 rivet so the same dimple is used. The MK rivet head is just slightly bigger but it is close.
You can very lightly machine countersink the dimple a few thousandths to get a bit better fit.
Scott McDaniels
Hubbard, Oregon
Old 02-05-2018, 01:33 PM
iamtheari iamtheari is online now
Per the current version of the plans, page 07-12, these are MK-319-BS rivets. Should the skin also be final-drilled #33 for these or is it punched for them?
Also, I've found references to the MK-319-BS rivet being 120 degrees. Should I use a 120-degree dimple die on these 6 holes in the skin?
Old 02-05-2018, 03:20 PM
You can always try inserting the specified rivet and see if it will go into the hole.
If not, then the hole is not to final size.
In this case, I believe all of the holes are punched .094 for 3/32 rivets. Some people are able to install regular rivets in these holes, so that gives them the option.
If you have 120 deg. dimp. dies for 3/32 rivets they could be used, but I think they are only available for 1/8" (#30 holes)
Scott McDaniels
Hubbard, Oregon
