Old 07-11-2017, 09:28 PM
Originally Posted by moosepileit View Post
I bet a few VGs in the right spot would remove the buffet. Do all series of wingtips act the same?
The buffeting has been attributed to the nose on the "up" aileron sticking down below the bottom surface of the wing and tripping the airflow as it passes under the aileron. 20 years ago (or thereabouts) Van tried VG's on the leading edge of the ailerons to address this issue. I never saw the results from that trial.
Personally, I might try the VG tape the sailplane guys use. Properly positioned on the LE of the aileron, it might keep the airflow attached and prevent the buffeting. Or it might not. ;-)
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 07-11-2017, 09:40 PM
If memory serves, when I 1st experienced it over 20 years ago in my 1st -4, I called Van's and they told me it was aileron *stall*. Empirical evidence supports this; higher airspeeds reduce the bumping.
Old 07-13-2017, 12:06 AM
nigelspeedy's Avatar
nigelspeedy nigelspeedy is offline
Default VGs probably won't help
I tried VGs on my RV-8 on the outboard wing leading edge i.e. in front of the ailerons. They made no difference to the stick buffeting that you are talking about or the roll rate under any configuration.
Cheers
Nige
Nigel Speedy
RV-8
Flying
Tehachapi CA
I paid my -VAF- dues July 2017
Old 07-13-2017, 09:33 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Cheers
Nige
What about VGs on the wing, but located just forward of the aileron hingeline (instead of the wing leading edge)? But since the buffet we are talking about occurs at large aileron deflections, that may not work either.
There are some large airplanes I'm familiar with that have VGs just ahead of the aileron hingeline to preclude buffet due to flow separation over the aileron under certain conditions. But those conditions usually don't involve large aileron deflections.
I should add that I don't think this aileron buffet is an issue that needs a fix on the RVs.
Carl N.
Arlington, WA (KAWO)
RV-8, 240 Tach Hours
(Pic)
- Out with the Old, In with the New (Pic)
RV-8, 1938 Tach Hours
(Pic 1), (Pic 2), (Pic 3) - Sold
Glasflügel H-201B Standard Libelle, N564NS - Sold
Rolladen-Schneider LS1-f, N61MP - No longer owned
