Old 07-11-2017, 04:08 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Originally Posted by ALMARTON View Post
I'm having a very slow rate on my RV7A
Define "very slow". How many deg/sec at various IAS?
Old 07-11-2017, 05:06 PM
spatsch spatsch is offline
Originally Posted by Smilin' Jack View Post
I know it has been adresses before and the general response was roll slower. But has anyone come up with a fix such as a flexible gap seal on the wing in front of the aileron? I was thinking of taping some very thin UHMW tape to the wing and letting it lay against the aileron to see if the airflow over the bottom and top of the aileron could be improved and eliminate the buffet... Like a gap seal
What do you think,
That little tapping feeling only becomes an issue in double rolls perhaps because my airspeed has decreased.
Also thought about vortex generators installed just adhead of the aileron.
Jack
I wouldn't really worry about it. It happens with my RV-8 at certain speeds too. The first time it really got my attention (I hadn't read about it before so it was a surprise during phase 1...) after a while you would miss it if it didn't happen.
Oliver
Oliver Spatscheck
RV-8 & J-3
N-2EQ & NC-49762
http://www.spatscheck.com/oliver
Old 07-11-2017, 06:19 PM
ALMARTON ALMARTON is offline
I recommend you that you do not tape the gap. A frise style aileron is designed to have airflow between the wing and the aileron.
I think you should look at your problem in a different way.....
If there is 9000+ RV's flying.... with good aileron response (without sealing the gap).... wouldn't it be better to figure out what is different about your airplane from all the rest?
I suggest you start with reading the portion of the current Section 5 of the construction manual regarding proper trailing edge shape of control surfaces.
Nice Scott! Many thanks as I did not built my plane I did not know about that. I'm going to look into it. Thanks again for the info
Alexandre "neck" Marton
Brazil
RV7A (8/2015 built by FLYER)
Lycoming 180 HP - YIO-360-M1B, Hartzell C2YR-1BFP/F7497 72, Garmin panel - G3X Touch, GTN650, GTS800, WX-500, BATT CONCORDE RG-25XC AEROBATIC SEALED.
Others: RV9A
Lycoming XIO320-D1A, Hartzell HC-C2YL-1BF/F7663-4 , CS GOVERNOR MTV-12-B, DYNON D180
AND GARMIN AVIONICS
(Sold with aprox 300hrs flown from Dec/2010 -- JUN/2014)
Old 07-11-2017, 06:22 PM
I wouldn't know how to measure it RV7A Flyer could you tell me?
I'm saying slow as compared with my former 9A who should roll slower than this new 7A but not...
I'm also saying it by a educated guess comparing two flown 7A I've got arround my base.
But It would help a lot if I coud measure... never thought of it. What would you say is the best method? To roll 360 and time it? Just as simple?
Brazil
Others: RV9A
AND GARMIN AVIONICS
Old 07-11-2017, 07:47 PM
Well I timed some videos doing tunneaus I had and ones I found and came up with the results:
Average roll for RV7 is 109 to 95 degrees/sec
Mine is doing 85 to 75 degrees/sec (very low as I had supposed)
My 9A (from timing its videos) did about 70 to 65 degrees/sec
Question how do I improve my RV7 roll rate? Clearly it was not feeling right now with some numbers it must not be right and needed to be fixed.
Any comments?
Brazil
Others: RV9A
AND GARMIN AVIONICS
Old 07-11-2017, 07:59 PM
1) Is your airplane rigged correctly? In other words, do your ailerons reach the specified deflections?
2) Do cushions or maybe your thighs block full stick travel?
3) What is your technique for rolling the airplane? Walk us through all of your control inputs.
4) Is your airplane stock? No outboard fuel tanks, no luggage storage in the tips, etc?
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 07-11-2017, 08:56 PM
1) Don't know I did not build it myself (wish I did). Bought it. Can you provide info on that for me to verify if it reaches specified deflections? Appreciate.
2) No.
3) Not much of a technique , most of the rolls I start at about 120 mph pitch the nose about 25 degrees over the horizon and apply full aileron (no rudder input at all). Most of time. This is my most common roll. Just use rudder in slow rolls. Should try it on normal ones?
4) Stock RV7A no mods. Brand new 143 hours , rolling solo with about 13 gals each tank (balanced and light). First flight October/2015
Brazil
Others: RV9A
AND GARMIN AVIONICS
Old 07-11-2017, 09:02 PM
2) No.
Regarding item 1: Do you have access to the instructions or construction manual for your RV-7? It should specify control deflections. I'm an RV-6 guy, so I don't have the data for the -7.
Regarding item 3: I believe your roll rate would increase up to about 150 mph and rudder input would increase the rate as well. Others may have data supporting my belief (particularly regarding roll rate vs airspeed).
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 07-11-2017, 09:10 PM
moosepileit moosepileit is offline
The IAC tech tips published a method of sealing Pitts ailerons and I liked it on my S1S.
My RV-6 has aileron throws in spec, slightly under in aileron, and they will give some thumping above 1 g near vA, less if unloaded a bit.
I would not seal them. The gap and amount of leading edge in the high pressure below the wing is not the same as the S1S. I bet a few VGs in the right spot would remove the buffet. Do all series of wingtips act the same?
Just a gut feeling. Plus, a 4 aileron Pitts may act differently if a gap seal becomes loose compared to an RV.
Exempt, but 2016 dues gladly paid!
RV-6 N91GG, bought from builder.
O-320, slider
Old 07-11-2017, 09:18 PM
Rudder definitely assists roll rate in a -4; no reason to think it would be any different in the other short wing models.
Is the roll rate really that slow in a -7? I figured it would be just a bit slower, but not that much.
