Old 07-09-2017, 09:31 AM
DBRuth DBRuth is offline
Default Cracker fly in
I saw your plane yesterday, but was unable to stop by and see you. I was driving the shuttle tractor and things were busy. Maybe next time, wanted to see if I could help with your Dynon. Not likely since I have a SkyView and am not real good with electronics, mechanical stuff is my forte. Hope Dynon gets you back up to speed.
N412DR
Kit 120797
First flight 8/21/15 what an awesome aircraft!
HOBBS @146
Old 07-09-2017, 09:37 AM
I was so busy I never got to see the 14 or Vic Syracuse. Vic did stop and talk to my wife. By the time I got a break, about 2:00, Vic was gone. Oh well, at least our new east coast rep is a short RV ride away now.
N412DR
Kit 120797
HOBBS @146
Old 07-09-2017, 01:44 PM
dick seiders dick seiders is offline
Thanks DB, saw your plane as well .Are you planning to paint it? Thanks for the offer of help, but I believe this is going to require a Dynon lookover so sending it out tomorrow.
Tried the testing for brightness again today while in different lite conditions and no change. Not so sure today that engine running has anything to do with it but don't know.
Pictures of what I am talking about will be sent to forum so all can see what I am experiencing. In all conditions the screen is operating it's simply to dark to be legible.
Hopeful that Dynon will have a solution. I sure don't.
Dick Seiders
Old 07-09-2017, 04:04 PM
Default Paint
I will eventually get some color on it, too much fun flying. Can't decide if I'll paint or vinyl wrap it. I cleaned it with alumaprep for the fly in, so it is nearly ready for paint/vinyl. Did I mention how much fun it is to fly.................
N412DR
Kit 120797
HOBBS @146
Old 07-09-2017, 06:07 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Default Dick's Pictures
Pictures of Dick's problem D-180:
In hangar with door open.
Outside with engine running.
During taxi.
In flight.
Dick Seiders
Tony
RV-12 #202 -- Flying
Old 07-09-2017, 06:43 PM
BigJohn BigJohn is offline
Well now, let's see. The only things that I can think of that change when the engine runs are the bus voltage, and vibration. How about checking the voltage with an external meter to be sure it is within specs?
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
RV-12 N37JP 120176 Flying since 2012.
VAF paid through 10/2018. Best bargain in town.
Old 07-11-2017, 08:11 AM
John, I always check the voltage at start and again at runup.It has never indicated a problem. I realize the data shown could be in error but if voltage too low wouldn't the battery back up power the display?
MMiller, I tried to find the sensor on AP after "do the time" suggested that. I could not find a sensor. Regarding having it on I have always turned on master, ignitions, avionics, and AP at start, and all remain on for duration of flight. Since I have done this consistently and the screen brightness issue is only six months old I have doubts about the sensor, but we may find out later.
At any rate the D180 is on its way to Dynon for review and repair and hopefully I will have causal info to share with all when it's completed.
Dick Seiders
Old 07-28-2017, 05:14 AM
Did this ever get resolved?
Hinckley, Ohio
PPL/ASEL 1970 Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 320
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 07-30-2017, 01:03 PM
Yes it is resolved . Just fin installing repaired D180 5 min ago. Before installing I lit it up on battery power and it's bright and readable in the hanger and outside in the sunshine. Haven't flown with it yet but am confident it will be good to go.
Dynon said the problem was a failed LCD module. I asked what failed and was told the circuit board. They don't go deeper than that level.
Dick seiders
Old 08-06-2017, 09:49 PM
nightflier nightflier is offline
Default Dim Dynon 180 also!
Increased bright to max, no help! We need a solution, I can't be one of the only two people to experience this.
Sam
