Old 06-28-2017, 11:00 AM
CubedRoot's Avatar
CubedRoot CubedRoot is offline
Congrats Marvin! Great to see that bird in the air.
I still have those wing stands you gave me, and will be putting my wings in them hopefully by the end of the year :-)
If you are ever down around the KCHA/KFGU/KRZR area let me know.
Lynn Dixon
RV-7 Slider -
Tail kit Completed - March 2017
Wing Kit Started - June 2017
My Build Log: http://www.theskunkwerx.com
VAF Donation paid for 2017
Old 06-28-2017, 11:11 AM
n982sx n982sx is offline
Marvin,
Congrats and what a nice looking airplane. Great videos too.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 07-03-2017, 11:29 AM
M McGraw's Avatar
M McGraw M McGraw is online now
Default Phase 1 Update
Hello,
I now have 11 hours on the airplane and I am more impressed with the Vans product than I expected. I am 5'11" and I have the rudder pedals in the middle location with the seat back in the most forward location and a 1" booster cushion under my Classic Aero seats. That position gives me very good visibility and my legs are quite comfortable. The aircraft is truly roomy. Stalls are basically benign both clean and full flaps. No wing drop just a little buffett and altitude loss. To recover simply reduce back pressure to break the stall then add power as needed to regain altitude. The landing flare is predictable and the gear are solid and consistent. It is surprisingly easy to land and stable during the rollout.
The controls are well harmonized without the pitch sensitivity I have experienced in many EAB aircraft. My first two flights concentrated on watching engine gauges and general control feel. I did need to adjust the propeller low pitch stop and the left aileron, but small changes like that are to be expected.
The third flight confirmed the adjustments previously made and I recorded the amp draw of each item I could turn on and off to verify my load shed ability since I have a totally electric aircraft including ignition and fuel injection.
Flights 4, 5, and 6 were used to calibrate the fuel flow and other engine sensors. Toobuilder previously posted a question on the SDSEFI fuel flow calculation. I do not have a flow meter in my system, I use the software inside the SDSEFI. For my IO-390 I turned the fuel pressure up to 49PSI from the factory standard 40PSI. This was done because to adjust air fuel ratio (AFR) at 100RPM increments you input a value between 0 and 255 at each increment which tells the injectors how long to stay open. At 40PSI I ran close to 255 at 2600 and 2700RPM. At 49PSI the numbers are lower and my average injector duty cycle is well below 60% (closer to 40% under most power settings). An obvious question would be why 49PSI and not a nice round 50? Well my Garmin sensor kit included a Kavlico P4055-50G sensor that is a 50PSI sensor and the numbers go blank at exactly 50PSI. I need to see if there is such a thing as a Kavlico P4055-60G? In the Garmin G3X system, for the fuel flow measurements I chose "Fuelscan 201B" and for the return flow I chose "none". With those selections I needed to increase the K factor about 17.25%; old K = 29500 new K = 34587. The K factor can be adjusted in either the SDS computer or the Garmin system to the same result, I chose to adjust the Garmin. I may tweak the K value slightly, but currently I am very happy with the fuel used versus fuel pumped at fill up time. BTW, increasing the fuel pressure may have increased the need to adjust the K factor?
A quick side note, we are very fortunate in the EAB world to have access to systems like Garmin, Dynon, GRT, etc... I have features I simply could not afford in my previous certified aircraft. These are many of the same features I enjoy at work, but that aircraft cost more than a lifetime of income, okay 20 or 30 lifetimes . Also the electronic ignition and fuel injection make starting my Lycoming as simple as pushing the start button. Imagine that, it starts as easily as my car which cost far less, no hot start or cold start procedures, just push the button . It runs VERY smooth and I have not yet balanced the prop!
Flight 7 served no purpose because weather interrupted my plan. I was testing the SDS fuel trim option. One thing I noticed is the Vans baffle system for the RV-14 is very impressive. I trimmed the fuel (about 1 to 2%) to match the EGT's and noticed the CHT's were amazingly even with lots of room to spare for my planned future cowl flap system. All my past experience with Lycoming was to find peak either on the Alcor gauge or by finding the "rough" spot then increasing mixture for best power. I tried to simulate that experience to my great surprise. As I leaned, the engine remained exactly as smooth as before. The EGT, CHT, and IAS changed then suddenly dropped yet the engine never gave ANY hint of roughness. I think I just experienced Lean of Peak and it was anti-climatic . I would have liked to continue learning, but weather intervened.
At this point, I am satisfied the engine sensors are good so my future flights will concentrate on calibration of the pitot-static system to see what speeds I can get. I really see no point in publishing speed numbers until I know they are accurate. Once I have accurate speed numbers I will move on to Vx, Vy, glide speed etc.. and I will work on my cowl flap system to see if it actually increases speed or merely CHT's.....
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 100+
2018 Dues Paid
Old 07-03-2017, 12:37 PM
Outstanding Marvin. I know alot of builders, and a few vendors are very interested in your flight tests!
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 07-04-2017, 03:21 AM
Gahannaflyer Gahannaflyer is offline
Congratulations Marvin!
I will be anticipating the walk around of your beautiful plane at Oshkosh.
I also plan to fly my 14A up there too. But I have a lot of little things to tweek to make my plane just the way I want it.
Fantastic job!
Steve Brown
Old 07-04-2017, 09:34 AM
M McGraw's Avatar
Default OSH
Fantastic job!
Steve Brown
Sadly,
I will miss Air Venture this year, it conflicts with my parents 60th anniversary party😊 I would like to see you plane. I go to Port Columbus a few times a year. Which airport do you use?
Marvin McGraw, 5TN4
Flight hours: 100+
2018 Dues Paid
Old 07-20-2017, 06:28 PM
M McGraw's Avatar
Default Phase 1 complete!
Today I completed Phase 1. I put the airplane in the hangar at exactly 40.0 hours. Completed the logbook signoffs and washed the plane. I patiently waited for my wife to get home from work. It seemed only fair that she would be the first passenger. If only she had let me do a little of the flying.
Marvin McGraw, 5TN4
Flight hours: 100+
2018 Dues Paid
Old 07-20-2017, 06:44 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Congrats Marvin! I detect 2 RV grins there.
Turbo Subaru EJ22, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 419.2 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 11-14-2017, 02:22 PM
M McGraw's Avatar
Default Update 85 plus hours
We now have over 85 hours on the RV-14. I am in the process of accumulating performance data to create a POH. The link below is the data to this point.
https://drive.google.com/open?id=1Bz...iapT-4Pxrv-Pow
This is my brother as we leave for KFFA, First Flight North Carolina
Marvin McGraw, 5TN4
Flight hours: 100+
2018 Dues Paid
