Old 06-22-2017, 09:58 AM
Windwalkerar Windwalkerar is offline
Default Gear leg question
What is the height difference between the tall gear and regular gear, and what are the benefits of the tall gear over the regular gear?
Old 06-22-2017, 10:08 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Tall gear
Lots of input in the archives including Van only sells long gear.
Larry DeCamp
RV-3B flying
RV-4 fastback project in the shop
Clinton, IN
Old 06-22-2017, 10:21 AM
Ok, thanks!
Old 06-23-2017, 02:23 PM
daddyman's Avatar
daddyman daddyman is offline
Windwalkerar,
I have the told short gear.
They work fine.
While I don't know the dimensional specs they create about a 4" increase in stance on the ground.
The primary advantage is that you have greater ground clearance for soft field landings and more distance between the ground an the prop.
This means that you have more prop options available (read longer). This can create more speed.
Good short gear are not worth changing in my opinion, but if you are starting from a partially completed project, it would be a plus.
I think this also means a different (non-compatable ) engine mount from the shorties.
Having "short" legs never bothered me.
I'd say "don't fix what is not broken".
Daddyman
Dues + paid
Old 06-26-2017, 02:31 AM
Doyle231 Doyle231 is offline
Never flown a tall gear rv4 but besides looks i couldn't see how you could justify converting a in service short to long. I have a 2 blade CS hartzell on short gear and believe if you got to the point where the prop would strike you would feel it in your seat and see it in your attitude. Before i purchased mine i put blades at 12 & 6 and lifted tail to level. Not an issue
RV4-0-320,C/S,967LBS
Light,simple and fast.
Just how vans designed it
Old 06-29-2017, 09:27 AM
Thanks guys!
