Old 01-26-2017, 06:03 AM
salto salto is offline
Default MK-319 rivets
I notice that the MK-319 rivets tend to dome a little during the setting event and was wondering 1- is this normal and 2- if not what is the technique to keep them flush ?
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 01-26-2017, 06:13 AM
Mel's Avatar
Mel Mel is online now
They should not "dome" if you are using the correct rivet set. Make sure that the hole in the rivet set fits the rivet stem snuggly. If the hole is too large, it will allow the rivet head to "dome".
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 01-26-2017, 06:29 AM
RV7ForMe RV7ForMe is offline
Default Good question!
Hey. I also will soon use these. (have not yet)
I just realized that the MK-319 pull rivets are actually larger in diameter then the #40 holes.
I have a chart and it says:
#40 2.4892mm or .098"
MK-319 2.7781mm or .109375"
I don't have a drill in these sizes. Do I need to get one?
What is the procedure commonly used here and may this be the reason they dome?
VAF dues paid until 05/2018
RV7 - Working on empennage 95% done
RV7 - Wings arrived and inventoried...
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 01-26-2017, 07:14 AM
KeithB KeithB is offline
MK319BS rivets are 7/64" requiring drilling a #34 or #33 hole - usually after dimpling with a #40 simple die. I also had domes on mine. I've tried everything under the sun without success to eliminate them.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, Phase I compl Apr 3, 2017, >220 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
Old 06-12-2017, 07:35 AM
bkervaski's Avatar
Mine do not sit perfectly flush either .. they "raise up" about 1/32 when pulled .. seems to be common when I look at other builds. Looking closer at the process; they sit completely flush prior to pulling but the act of pulling is what raises it up.
My guess is the tool we're using and the method. I'm using the Craftsman puller (yellow) provided with my tool kit.What puller are you using? When I pull mine I do not push down rather add upward pressure to get the tool away from the skin so it doesn't snap back and ding/scratch the skin. I bet this is what's causing mine to raise up a bit.
Progress: Final Assembly
Old 06-12-2017, 08:50 AM
mturnerb mturnerb is online now
They do stand slightly proud. I plan to fill them in, sand, paint and fly on. Doubt I will notice or care much when it's flying.
Turner Billingsley
RV-14A In Progress
N14TK Reserved
Old 06-12-2017, 01:51 PM
TimO TimO is offline
Bkervaski: Don't pull up when pulling those blind rivets. Push down instead. Sure, you may scratch the skin if the thing jumps, but, when you paint you will need to completely scuff the skin anyway (unless you are going for the no-paint polished look?). Scratches happen and they won't be seen after paint. If you absolutely feel you have to protect it, get a rubber pad with a hole in it to center on the rivet as a protector....like the fuel filler pads the line guys use only small for riveting. But don't pull on the rivet as you squeeze the pop-rivet tool.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1300+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 175+ hours http://www.MyRV14.com
RV-10/14 Transition Training: http://www.RVCFI.com
Old 06-12-2017, 01:55 PM
bkervaski's Avatar
Thanks for the tip .. not going crazy just enough pressure to try to avoid those dings. We started using masking tape around each one. I'll try to apply pressure on some and see what happens.
The scratches don't bother me but I dinged one good early on and made a skin replacing dent. Needless to say I'm better at it at this point but that memory stuck.
