Old 10-20-2014, 08:05 PM
Stockmanreef Stockmanreef is offline
Default Washer 5702-475-48 Z3
anybody have the dimensions of these washers? They are used to attach the ailerons and the aileron pushrods. I am not exactly sure which ones they are.
thanks
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 10-20-2014, 10:36 PM
Jake14 Jake14 is offline
you get lots of hits if you google that number. One of them is:
WASHER 5702-475-48 Z3 .190X.562X.048 WASHER
would the #'s on the right be the dimensions?
Old 10-21-2014, 03:33 AM
TedsNumberOneSon TedsNumberOneSon is offline
They would be the dimensions.
Terrell Yon
Orlando FL, KCOI Merritt Island Home airport
140173 Kits Underway
Tail kit structurally complete
Wings in progress
N87TY on hold
EAA 724 and 74 Member
Old 10-21-2014, 04:45 AM
Ron B. Ron B. is offline
Big zinc plated flat washers?
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 10-21-2014, 12:38 PM
These are important parts. They are larger than the rod ends, so if a rod end bearing actually came apart these washers keep the control linkage from coming completely apart.
Old 10-21-2014, 02:23 PM
I thought that they were the big zinc washers, but wanted to make sure.
Ken Stockman
Midland, MI
Old 10-21-2014, 04:32 PM
Ken, did you understand Bob's explanation , as to the purpose of the washers?
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 10-21-2014, 06:13 PM
yes. Understood. I thought that I had picked out the correct washers. I was just checking to make sure.
thanks
ken
Ken Stockman
Midland, MI
Old 08-18-2018, 09:02 AM
MElstien MElstien is offline
Default I found mine in Bag 1215
I found these washers in Bag 1215 with the aileron attach brackets. There were 4 of them.
Michael
Builders Blog http://elstien.us/wordpress/
Northern NJ
RV-10 Builder
Tail Kit delivered 6-2013
Started building April 2014
Empennage completed
QB Wing and Fuse Delivered December 2015
Finishing QB wings on September 2018
Moved to Port Orange FL November 2018
Project moved to Port Orange Feb 2019
Dues Paid through 2019
Old 08-18-2018, 10:32 AM
JTJones's Avatar
JTJones JTJones is offline
You may want to consider replacing those zinc plated Z3 washers wherever they are called for with cadium plated AN 970 washers. The zinc ones will corrode over time.
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
VAF dues paid plus beer money😜
