Pilot135pd
I just read an article in a magazine that left me very confused regarding my RV-8. I?m not a mechanic or a builder so it might have a simple explanation but if not I found it to be a major safety issue.
This is what the author said:
?Wherever a bolt is subject to rotation, it is required to have a castellated nut and cotter key. A typical mistake I see on amateur-built aircraft is the use of a heat nut or fiber nut on the rudder control horn. The second picture shows the proper bolt/nut combination; however, the cotter key is missing.?
So I went and looked at every one of the nuts on my ailerons, rudder, and elevator and they don?t have cotter pins. Aren?t those bolts subject to rotation?
