Old 03-15-2019, 07:59 PM
texdog texdog is offline
Question Ads-b new n number
I have ADS-B in and out with Echo/uAvionics with GRT AFIS. I'm changing my N number. How do I change the whole system to the new number?
Thanksgivings
T82 Fredericksburg,Tx.
Don't make easy hard!
Master Pilot Award
RV6A owner
L19 sold
ATP/FE/CFI 10 Type Ratings.
Old 03-15-2019, 09:20 PM
Jpm757 Jpm757 is online now
Your new registration will include a hexcode unique to your aircraft AND N number. I am not familiar with the GRT or UAvionics, but there should be a method to enter the code which will then send the data out through ADS-B.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 250+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. KOXC Oxford, CT
1941 J3 Cub skis,floats.
2019 dues gladly paid.
Old 03-16-2019, 06:31 AM
Skysailor Skysailor is offline
Default Echo UAT setup
The hexidecimal identifier is entered on the setup page for the Echo UAT from your phone or iPad. When you get the new N number, go the the FAA site and see if they changed your hexidecimal code as well. They probably will have done so. Go into setup and change both. Save the configuration before exiting. It will be important to change both at the same time since flying with the new version of one but the old version of the other is not legal. Send me a PM and I can walk you though it on the phone if you like.
RV4
Paid through 2019! How about you?
Old 03-16-2019, 06:39 AM
BH1166 BH1166 is offline
Thanksgivings
Are you using the SKYFYX from uAvionics for your GPS source or SafeFly2020 from GRT? If using the SafeFly2020 WAAS GPS AND are using it for the GRT EFIS, setup and change will be made on the EFIS vs the EchoUAT app.
Butch
RV6A Purchased N72TX
2019 Dues Paid
