Old 08-04-2018, 03:27 PM
djborko11's Avatar
djborko11 djborko11 is offline
Default Error Proofing and Organization
I'm in the early stages of the build, absorbing as much as I can at this stage. So last week at Airventure I picked up this handy tip.
Put all the bagged parts with the same part number in a single container!
Dasani 12 oz water bottles make great containers for rivets!
I used my handy Dymo labeler to label the rivets for the water bottles and a fine point sharpie identifies the components compartment boxes ($2.99 HF)
My expectation is that I'm less likely to grab the wrong rivet or bolt this way.
[IMG]//https://lh3.googleusercontent.com/p44ikb7_HtI_74DmBr6e9rQbVlulx36Az1VU-sqrCW_8MI3cRkp_uoZhKqGIajbG6aKX5oPEVVx6KNPinbt7dNA IFqVKqVUptkdXGaWrlSCf6aD8rpAZ7D_E6VJwFy84B3bkbrNjM tVXB5agNaoPwx4_wl6C60I0JC2MDFNAuTRjpXb7RpGMGpVVLxP AgyabRRmS5C3VNYLdVdytT_8ZsMc-gtG0-k_ik3qLfKxQohm8Y21lLf4x9bnqHIf21Q7sCm571traYT5ni17 OxH4TtJ0XjJUlB8cFmqOCOxLDFsJF6-_GXs4abhlUxUJcGjbdNrG142lcAO5j10j1YQoT1rv1UkJaGkPw 2ZsryHwc9OfdEhLo0MSN3Wf3ef8DS72q7PJ10HZsf6LDKXMhwI dszJdbvyYVBauYygl5RYnWQ5eJFVx9CUWQ3ScCtWnoy-UWzsMCMecO2S0K_iyN-d5yhxEyEJDhZEtKtUNZ3b3zLzat8Y_1FV2vg5AGyKEjvY9Lulh nsTRXoxcTH84-WL5-bktWBGUKHOha5WJ14-kl_MGatJbVswmk05M1qBOYCa6TctYOzZrkg_oaCUAKsHqPDPoj N6n55izK24kIKrFr1UokmL5bYNp-5BrAYoq3drViUvYjmaAY9DpbzKWQ3bENZqczERji2jan=w800-h600-no[/IMG]
D.J.B.
RV-14A #140356
East Aurora, NY
Empennage in Process
Old 08-04-2018, 03:32 PM
djborko11's Avatar
Original post missed the second picture....
D.J.B.
RV-14A #140356
East Aurora, NY
Old 08-04-2018, 03:43 PM
snopercod's Avatar
snopercod snopercod is online now
You're doing the right thing! Be very careful when choosing one of those compartmentalized trays. Yours looks like a good one but I put all my #8 machine screws in one with each dash number in a different compartment. I dropped the tray once and all the dividers all popped out. It took me weeks to get them all sorted out again.
(2018 dues paid)
Old 08-04-2018, 04:08 PM
Default Yep...
DO NOT DROP THE TRAYS!
You are doing it right with the inventory...it will save you loads of time during the build!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 08-04-2018, 05:23 PM
wirejock's Avatar
wirejock wirejock is offline
Default Parts bins
My Mentor Dave Paule tipped me to those bottles. Fabulous idea. I also use paper bowls for the bench. I put the bottle in the bowl and dispense only what's needed for the job. Since the bottle is labeled, I always know whelat size is in the bowl.
Harbor Fright sells 40 drawer bins. I have one each for nuts, bolts, washers and misc. Every drawer full. I use storage bins for smaller parts. My Excel inventory has nots for where every part is located. Then I use a building storage bin for all the parts for the component in progress.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 08-04-2018, 05:35 PM
Very clever good job Dave. Organizing is very important each of us is doing it our own way. I like yours.
Old 08-04-2018, 06:29 PM
airguy's Avatar
airguy airguy is offline
And you can save space by running a screw through the cap of those bottles upward into the bottom of the shelf above your workspace - and then screwing the bottle into the cap. Apply the label on the bottle showing contents for proper orientation after the bottle is screwed into the cap.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 380hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
