Old 01-03-2010, 07:20 PM
elippse elippse is offline
Default Jim Smith's RV-6 wing tips
Have any of you seen Jim Smith's new wing tips on his RV-6? They've upped his AR from 4.8 to 5.8, increased his span to 26' and his area to 116 sq. You can contact him at elippsefppropsales@gmail.com, and ask him for some pix and performance data!
Old 01-03-2010, 07:32 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Default Nope
Originally Posted by elippse View Post
Have any of you seen Jim Smith's new wing tips on his RV-6?...
I haven't. Is it possible? There must be a photo somewhere on the Interweb.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 01-03-2010, 07:35 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
And you can post this info here pics etc... ??
Reiley
N622DR - Serial #V7A1467 RIP Aircraft Drowned in the 05/2015 Memorial Day Flood
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 01-03-2010, 08:27 PM
fehdxl fehdxl is offline
Default here you go...
Not the best picture, but the only one I can find right now. This was at Table Rock, MO in Aug '09.
-Jim
40603, fuselage
Last edited by n5lp : 01-03-2010 at 08:32 PM. Reason: Edited image link for bigger photo
Old 01-04-2010, 02:53 AM
Bob Axsom Bob Axsom is offline
Default What is the purpose?
I met Jim Smith in Wichita a while back and he seemed like a reasonable guy. He was flying in the cross country air race with a prop that you designed I believe - it looked like the one in the previous post photograph. I am currently working on molds for wingtips that will reduce the total wingspan to approximately 21' 1" for speed improvement. Why is Jim increasing the span to 26 feet? I assume he is looking for better performance at high altitude or some STOL performance. Has he changed the gross weight? Is he adding fuel out there? Just idle curiosity - I'm going the opposite direction.
Bob Axsom
Old 01-04-2010, 06:04 AM
pierre smith's Avatar
Default My concern....
....would be the added bending moment on the center spar structure. That's a lot of wing added.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor AT 502B PT 6-15
Air Tractor 402 PT-6-20
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-04-2010, 10:00 AM
WingsOnWheels WingsOnWheels is online now
While we are on the wingtip subject, has anyone tried small winglets?
Colin P.
RV-6A #20603:Painting and moving to the airport for final assembly. Getting very close!
PP SEL / A&P
N616CG (Reserved)
I donate every year on my B-Day (in Dec)
Old 01-04-2010, 11:24 AM
rv72004 rv72004 is offline
Best,
I was thinking the same thing actually. Does Vans have a point of view on lengthened tips ?
My Glasair III wanst rated to 6g with the extended tips, only 3.8 if I remember correctly. 6g only with short wing.
The tips really slow up the roll rate and stall speed. Speaking from experience.
Me thinks vans should be consulted before installing these long tips......
EJ
RV7 flying
xp360, CS, All Glass cockpit
Old 01-04-2010, 12:50 PM
Default Van does not like the wings to be lengthened
I discussed this with him briefly in October of 1996 when I was at the training session at North Plains, OR and I was going to install the 9" wide (18" added wing span) tip tanks. He was very uneasy about it and advised me to add the tankage inside the design envelope like Jon Johanson had done. I have flown the 24.5' wingspan for years with no problem but when I go to the 21.5 feet in the racing configuration the roll rate is noticably faster. I am working on a 21.08' configuration.
Bob Axsom
Old 01-04-2010, 02:25 PM
Sid Lambert Sid Lambert is offline
It looks like a giant delta dyke from that angle.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
