Old 12-21-2009, 12:45 PM
Tumper's Avatar
Tumper Tumper is offline
Default J B Weld vs. Pro-Seal
Can someone extol the virtues of Pro-Seal vs. J B Weld? I am repairing some small plastic parts (not sealing fuel tanks). What exactly is J B Weld?
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
Old 12-21-2009, 12:52 PM
G-force's Avatar
G-force G-force is offline
It is an epoxy based with powdered metal fillers. It dries hard so it is good for repairs where you need to fill a void and can be sanded, tapped, etc. But its very poor for anything flexable like plastic, it will just break away or crack. Proseal is more of a flexable, fuel resistant sealant. While it does act like an adhesive, its bond strenght is pretty low compared to a real adhesive. For your application, something rated for the type of plastic you are repairing will be better than either proseal or JBweld.
Mike Sumner
Castaic, Ca
2018 dues paid
Old 12-21-2009, 01:36 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Try this stuff...
...which is available (or a very close equivalent) at Home Depot...
http://paint-and-supplies.hardwarest...xy-108771.aspx
It's different since it will bond to ABS which most epoxies won't do.
It does have a short working time though....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-21-2009, 01:40 PM
Captain_John's Avatar
...or you could try Marine-Tex.
It is a 2 part structural compound that is designed for plastics... primarily fiberglass boats.
CJ
RV-7 Flying - 810 Hours in 3 Years!
Old 02-13-2010, 03:09 PM
turbo turbo is online now
Post
my vote is for marine-tex. been using it for too many years to admit. can be mixed to be flexible or rock hard.
TURBO YES =VAF= Payed Jan2018
RV6-A 5,000+ hrs, R-44 1,600 hrs, Helicycle 280 hrs, gyro sold,35,000 miles flown in 2015
Old 02-14-2010, 06:27 AM
rv72004 rv72004 is offline
As the marine environment is one of the toughest out there, I second most marine products [glues, fillers, sealers etc] to be good for aviation.
Have had good results with the marine products.
EJ
RV7 flying
xp360, CS, All Glass cockpit
