Old 07-07-2010, 10:10 AM
bkthomps bkthomps is offline
Default 1watt laser for cutting blue vinyl coating?
Who thinks this laser from wicked lasers would actually serve as a good replacement for the soldering iron tehcnique of cutting the plastic away from skins? I was thinking of the reflective quality being obviously bad, but if it can burn a match stick in half........
thoughts???
http://www.wickedlasers.com/lasers/S...ies-96-37.html
Brian
RV7 - Finishing, Who knows, make me an offer
Lancair Super ES-TN - G3X Touch/GTN
RV4 - Skyview Sold!
Old 07-07-2010, 10:30 AM
kevinh's Avatar
kevinh kevinh is offline
I do a lot of work with high power lasers. Anything over .5 watt + reflective surfaces is bad ju-ju. I'd say stay away. Eye damage can occur before the blink reflex kicks in and you won't even know it till later.
http://en.wikipedia.org/wiki/Laser_safety#Class_4
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 07-07-2010, 10:32 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Default Thoughts???
Originally Posted by gimp2x View Post
thoughts???
Ummm... my only thought is also something like "Do Not Look into the Reflected-off-Shiny-Aluminum Laser Beam With Remaining Eye" ?
Definitely want some seriously industrial-quality laser eye protection goggles when messing around with 1-watt laser.
EDIT: It takes a pretty deliberate effort to put your eye out with a soldering iron, and the soldering iron costs a whole lot less money than the laser and will get the job done quite well. Still, that laser sure has some serious geek-wow-coolness factor to it, and I wouldn't mind owning one myself just for that alone.
Neal Howard
Airplaneless once again...
Old 07-07-2010, 10:36 AM
good point, it comes w/ protective eyewear- so assuming that is not the issue here, would it harm the aluminum? would the reflected laser be just as dangerous? i have zero clue about lasers, but i have a lot of vinyl to cut when my wings get here
Brian
RV4 - Skyview Sold!
Old 07-07-2010, 10:45 AM
FresnoR's Avatar
FresnoR FresnoR is offline
Default Sweet
I don't know about aluminum, but I would love to use that to start my next campfire!
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 07-07-2010, 10:55 AM
Neal@F14's Avatar
Probably would not hurt the aluminum since the beam would be mostly reflected, but I would guess that it might get hot enough to set the vinyl on fire instead of just melting it, which wouldn't be desirable at all.
You would have to ensure that no other people are standing around the hazard area without eye protection too.
The laser beam would probably also be a bit more difficult to cut straight lines since you'd have to guide it by freehand. With the soldering iron, you can just simply zip the tip alongside a metal yardstick to quickly make nice, pretty, straight cuts thru the vinyl.
Neal Howard
Old 07-07-2010, 11:45 AM
rv72004 rv72004 is offline
would it cut a canopy ??
EJ
RV7 flying
xp360, CS, All Glass cockpit
Old 07-07-2010, 11:46 AM
Rick S. Rick S. is offline
After taking all the time to make the neat looking stripes on the aluminum during my build then taking many scotchbrite pads to ALL of the surfaces during paint prep.....I would never waste my time cutting off the plastic again.
YMMV, it does look cool though
Rick Sked
Las Vegas
Old 07-07-2010, 12:25 PM
Flyguytki's Avatar
Flyguytki Flyguytki is offline
Cutting the canopy?? One small slip would be a costly one......
-david
RV-7 N87DX Built, Flown, and Sold!
"To those in this hour who are in the fight and keep our enemies awake at night"
Old 07-07-2010, 12:42 PM
BlackRV7's Avatar
BlackRV7 BlackRV7 is offline
I laughed out loud reading the warning post....do not look into laser with remaining good eye...good one
With that said, as a repeat offender, you are going to go over the entire airplane and scuff it up before you paint so just go ahead and remove the blue plastic now. The longer it stays on the harder it is to remove plus there have been numerous people who discovered corrosion under the blue plastic after they had finished a part and left it on the rack, in the corner, in the rafters for some length of time. On the 10, as with the 7 after I was about 1/2 way through....I'll remove the blue plastic.....and not with a laser
Dana Overall
Richmond, KY i39
http://www.DanaOverallCPA.com
Repeat offender, RV-10 emp
Builder/former owner, RV-7, "Black Magic" Flying
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
VAF #993
