Old 04-19-2013, 04:40 PM
Bart Bart is offline
Default Nose Landing Gear Play
Hey guys, I've been flying my -10 for 4 years now. I finally replaced the nose tire and noticed when I had the nose off the ground that there was some play in the landing gear....not a whole lot but enough to make me check all the bushings. I don't normally lift the leg up but when I checking torque's and generally inspecting the nose wheel area I lifted the gear leg and found very slight vertical and lateral movement. The plans don't mention play limits and its been too long since I first installed the gear to remember if I had it from new or not. The bushings were fine and the gear shows no wear...I'm thinking I may be over thinking this but was curious if others noticed this when new because I can't remember.
Old 04-19-2013, 05:01 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
If your nose gear has vertical motion when it is unloaded, it simply means the rubber shock "donuts" have compressed. Vans provided, with your kit, extra washers to be used and installed just for this reason. The washers are installed at the top end of the shaft under the "top hat". I am sure you can obtain these from Vans.
If you have lateral movement, I would check the bushings at the gear leg pivot points.
Bill Peyton
RV-10 - 890
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Old 04-19-2013, 05:10 PM
The rubber donuts do settle in a bit, that may be the source of your up/dn movement.
See page 46-7, upper right hand, second paragraph (I think it is) discusses adding a second u-1002 washer after the donuts settle.
Old 04-19-2013, 06:48 PM
Totally forgot about those washers. I'll dig those out tomorrow. In the mean time I have replaced all the bushings however there was no apparent problem with any of them. Thanks for memory jog.
Old 02-01-2018, 10:14 PM
Kyle Boatright Kyle Boatright is online now
Sorry for the necropost, but this is the only thread that mentions the appropriate part number. What are the U-1002's made from? I have a total of 4 aluminum washers that would seem to be the right parts, but they don't have a part number.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-02-2018, 09:22 AM
9GT's Avatar
9GT 9GT is online now
Those are the ones. Stamped out of aluminum sheet stock. De-bur before install.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2019
Old 02-05-2018, 09:17 AM
Paddy's Avatar
Paddy Paddy is offline
Default Check your bushings
I still had considerable play in the nosegear leg after properly compressing and preloading the elastomer discs. This turned out to be because of the sloppy fit of the VA 143 ans VA144 bushings in the nose gear link and engine mount weldments. I ended up turning some new bushings that fit better but Vans also sells oversize bushings to fix this problem. The VA143 bushing fit was poor enough to make me think the elastomers were loose at first because of the vertical play in the gear leg.
Flying as of 10/30/16 after 8 yrs building
Old 02-07-2018, 09:16 PM
On a related note, I have one of the aluminum washers installed under the WD-1015 (that's the cap on top of the shock strut), and am struggling to compress the donuts far enough to install the bolt which secures the WD-1015.
At this point, the main gear is off of the ground and the airplane is supported by the engine hoist lifting the very front of the nosegear strut and by sawhorses under the tail. In other words, I have maximum mechanical advantage to compress the donuts.
Despite that, I cannot compress the donuts far enough to install the bolt through the WD-1015. Eyeballing it, I need to compress the donuts another 1/8" or so. Even with me doing a pull-up on the engine mount to add more weight, I'm not getting there.
Since a few hundred folks have already solved this problem, there must be a better answer.
Suggestions?
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-08-2018, 03:22 AM
Default Washers
How many washers are you trying to put in? When I did mine, only one would come close to fitting. With the engine mounted, I pulled down on the mount using body weight, and the bolt went right in...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 02-08-2018, 05:11 AM
rvdave rvdave is offline
I believe someone posted about a ratchet strap around prop hub and gear leg to compress enough for bolt to slip in.
Dave Ford
Cadillac, Mi
