Old 12-01-2010, 01:54 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
OK, I am going to answer my own question here for future reference RV10 builders.
So I made contact with Hartsell and asked them about my prop & hub STD VANS RV10 [C2YR-1BFP/F8068D. 80” diameter, “blended airfoil “] and spacing, I send them the Vans Drawing and they made these comments on it.
It is NOW VERY CLEAR.
If you are using the Actual Spinner Backplate as a prop simulator then:
Your Flywheel spacers will be the distance of 2.247" MINUS the thickness of the spinner backplate material. Remember this depends if you have the doubler ring installed or not.
If you are using a flat plate then your flywheel spacers is 2.247 MINUS the skirt length of the Spinner Back Plate.
I am not home to give you those thicknesses of those items though, but at least you can calculate it perfectly.
I hope that clears it up.
Regards
Rudi
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 12-01-2010, 05:03 AM
rleffler's Avatar
rleffler rleffler is offline
Rudi,
Thanks for the follow up!
I'll be tackling this step in January. That is assuming my engine actually ships this week. (Lycoming was suppose to ship on 11/1)
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 12-01-2010, 08:57 AM
My pleasure BOB, glad i can help, and hope you get your engine soon!
Old 07-01-2012, 05:01 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
I am looking at using the 3 blade Blended Airfoil Hartzell prop and it has a dedicated spinner. Does the spinner include the back plate and spacers in this case? If so I can just order that and use that to work up the cowl spacing.
CharlieWaffles - But you can call me "Mark"
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 02-13-2018, 08:53 PM
Regards
Rudi
Following up on an old, old post for clarification.
What cowl/spinner gap does this method produce?
(I've been chasing a complete summary of prop/spinner clearance for two days and cannot find one post that puts all of the pieces together.)
PS, I'm looking to net a 1/4" cowl/spinner gap.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-13-2018, 09:04 PM
Bill Boyd's Avatar
Default Doesn't hurt to ask...
Anyone ever made a jig to fit the cowl without an engine mounted?
Or is this a risky and therefore dumb idea?
Be neat to be able to do this before the engine is purchased/hung if feasible - but I doubt it is. Too many variables, I suppose...
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 02-13-2018, 09:36 PM
Jpm757 Jpm757 is offline
Flyboy's rents a really nice cowl installation tool that worked very well for my RV7 cowl and MT prop installation.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 170+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub skis floats.
2019 dues gladly paid.
Old 02-13-2018, 10:28 PM
Coincidentally, I have one of those, and it is very nice. But I don't have the dimensions to effectively use it.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-14-2018, 07:41 AM
Bill Boyd's Avatar
Great. Now all I need is a jig to affix it to the engine mount in place of the crank and case.
I guess this dilemma is what unsalvageable cases and cranks get repurposed for.
Bill Boyd
Old 02-14-2018, 05:30 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is online now
Default Fitting the cowl
Originally Posted by Ivan Kristensen View Post
Here is a link to my photo album http://ivankristensen.phanfare.com/2...D=69090517with pictures and description of my cowl installation.
Ivan K.
The above link is no longer valid since I switched to SmugMug. Here is the new link
https://ivankristensen.smugmug.com/B...-installation/
Ivan Kristensen
Guelph, ON. Canada
RV-10 (C-GMDV) 1150hrs.
Dual GRT 8.4" EFIS, TT A/P, Avidyne IFD440, Dual EI's
Link to my build site:
https://ivankristensen.smugmug.com/B...ENTAL-aircraft
