Old 02-12-2018, 03:45 PM
OrenAir OrenAir is offline
Default 10-13 reduced diameter on J-CHANNEL
Page 10-13, step 2. Use a reduced diameter female die on the J-Channel of the bottom skin.
The holes along the skin edge that are about 1/2 inch away from the J-Channel on the skin itself, or the stiffeners that connect to it? It seems like the wording wants the skin edge holes but I don't see why to use a reduced diameter. There is lots of room. What am i missing?
Old 02-12-2018, 03:51 PM
bkervaski's Avatar
Your die may be fine, I didn't have to use a reduced diameter every time they called it out, however, they are calling it out so you don't damage the part as there may be a slight curve from the forming process.
Edit: Kind of like fluting if you deform that curve accidentally with a die it could twist the skin.
Progress: Flying!
Old 02-12-2018, 04:35 PM
So it's talking about the holes on the actual skin? They just seemed too far away to be "on the J-Channel". Maybe I'm overthinking it.
Old 02-12-2018, 04:41 PM
bkervaski's Avatar
The F-01478 skin has a J-Channel formed along the edges., not the holes that F-01486C attaches to. They don't want you introducing any twist by the die deforming the curve from the skin to the channel.
Progress: Flying!
Old 02-12-2018, 04:59 PM
Ah, so it's stay small to stay far away, not stay small to fit. Thanks Bkervaski
