Old 02-10-2018, 12:12 PM
Eztroller Eztroller is offline
Default AD3 & #40 countersinks
Howdy,
Page 8-04, Step 6: Machine countersink the middle nine holes (shown in Figure 1) in the top and bottom flanges of the HS-00902-1 Front Spar for AN426AD3 flush rivets.
Page 8-08, Step 4: Machine countersink, for dimples in .025 thick skin, the #40 holes in the flanges of the HS-00902-1 Front Spar and HS-00903-1 Rear Spar that correspond to the HS-00901-1 Skins
The bold underlined directions are confusing to me..... What is the difference between a countersink for an AD3, and a #40? Wouldn't these be the same?
Old 02-10-2018, 12:33 PM
salto salto is offline
AD3 hole size is #40. In the first instance the rivet will be flush so set up your countersink accordingly, in the second instance a dimpled skin will need to be accommodated so the countersink will need to be slightly deeper to allow for the skin thickness so it lays flat.
Info in section 5 on this.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 02-10-2018, 05:26 PM
Thank you!
Old 02-12-2018, 08:37 AM
Marc Bourget Marc Bourget is offline
Keep in mind, "so it lays flat" means no more than .002" between the countersunk member and the dimpled skin."
Old 02-12-2018, 09:09 AM
Not necessarily...... It depends on where you are measuring.
Section 5 gives a specific recommendation for countersink depth for a dimple regardless of the thickness of the skin that is dimpled.
Different skin thicknesses can result in differing amounts of gap between the sub structure and dimpled skin, in the areas between the rivets. From a strength consideration a small gap here is not of concern.
The strength comes in tight joints at the rivet locations. This is where no more than .002" is acceptable. It is also why the .007" deeper for a dimple rule is used. It will assure that in all situations, the dimple fits tightly in the countersink with no compromise in finished appearance.
Scott McDaniels
Hubbard, Oregon
Old 02-12-2018, 11:17 AM
OrenAir OrenAir is offline
I'm constantly impressed by the knowledge shared by Scott on this forum on a huge variety of topics.
Old 02-12-2018, 11:35 AM
krw5927 krw5927 is online now
No kidding! You'd think he WORKS for Van's or something!
Kurt W.
RV9A
FLYING!!!
Old 02-12-2018, 02:26 PM
Bavafa Bavafa is offline
Another one that got me, not remembering the section, it ask to drill 1/8" drill bit and later on asked to drill #30. I always took #30 as 1/8 size, only to learn that there is about a three thou difference. Now that is precision.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 02-12-2018, 02:45 PM
swisseagle's Avatar
swisseagle swisseagle is offline
Default How does it looks when you countersink to deep?
This is the most building error that builders do, countersinking far to deep to nest a dimpeld sheet onto aluminum structure.
Look at this picture:
This is a piece of aluminium angle, drilled and countersunk to accept a sheet aluminium which is dimpled. Then immersed in epoxy, cured, cut and grinded. So that the desaster gets visible ...
From left to right:
1. The aluminium angle is countersunk until a AN426AD-3-X rivet sits flush.
2. Countersunk until a AN426AD-3-X sits 0.01" deeper than flush.
3. 0.018" deeper than flush.
4. 0.02" deeper than flush.
The picture is not perfect, nor the samples are ... but it shows clearly what will happen. Where metal to metal is in contact and where are gaps. The gap between the angle and the sheet material, between the rivets doesent matter at all, but the gap of the two materials inside the countersunk hole and the dimple let me feel unconfortable!
For sure this got measured with a rivet ... which has also its tolerances.
The measurements are done by a caliper ...
Stay strong with Vans instructions, chapter 5 ! as Scott mentioned (he was working many years for Vans Aircraft btw ):
The clicks may be not the same on all brands of countersunk cages! Test on scrap first.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 02-12-2018, 02:58 PM
How do you measure “deeper than flush,” after the countersink has been completed?
