Old 02-10-2018, 12:33 PM
gerrychuck gerrychuck is offline
Default WTB: EI egt probes
If anyone is upgrading to a different system, I'd be interested in picking up your Electronics International egt probes. I currently have a single egt feeding my 8 channel smartscanner, and would like to have all 4. Either Fast (preferable) or the old "Robust" (read: SLOW) probes are ok.
Gerry Julian
Moose Jaw Saskatchewan
RV6A "Second Wind" C-GERZ (born N242UL)
O-360 A1A, Sensenich FP prop
Those who think any system is foolproof greatly underestimate the ingenuity of fools
Old 02-10-2018, 02:37 PM
RV8TOR RV8TOR is offline
I have a fast probe that I installed but never flew with. I had one go bad and ordered the fast by mistake instead of the robust like the other 3. I installed this one but did not like them not matching so I ordered the correct one. I did trim the extra length off of the hose clamp but it has not been hot. EI would not return it since the clamp has been trimmed.
Charlie Kearns
2009 RV8 N213CK
1976 C180 N9979N
Old 02-10-2018, 02:41 PM
Dan92 Dan92 is offline
I have a set of GRTs that you can have if you are interested.
Dan
Old 02-10-2018, 03:13 PM
Dan
Would they work with the EI head unit? Doing a bit of research it looks like the GRT system uses type J probes, while EI uses type K. My regarding this topic is very limited (i.e. 30 minutes of googling just now) so anyone with insights on this topic, please feel free to straighten me out.
Gerry Julian
Old 02-11-2018, 07:55 PM
It appears that any ungrounded type K probes can work, if anyone has any available. Thanks.
Gerry Julian
