Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 02-13-2018, 08:42 PM
crabandy crabandy is offline
I fired up the programmer and found out that I do have the EM-5 with an older software version, with the current software I can have the LOP functionality.
I watched some videos online about the controller and found after scrolling through the menus and verifying my current settings made me comfortable operating the controller. I left the low RPM timing set at:
500--10*
750--15*
1000--20*
I Changed Higher RPM 1250 and up to 23*. I input the advance schedule below.
A couple flights later left me more confident in experimenting with the timing and a little head scratching. I flew the same manifold pressure advance schedule at both 23* and 25* RPM timing above 1250 RPM.
Test flights were take off, set 90 KIAS engage autopilot on IAS/HDG to be established prior to 2000 PA where I timed the climb to 7000 PA. LOP was at 7500 and 21" map. Not enough data by any means to average out my results but here's my initial observations. 25* ran better throughout the range with:
-better idle
-10 seconds less time to climb 1000-7000 PA
-Approximately 10* less CHT
-Smoother and further LOP
-(From memory) Stock EFII curve was similar CHT's and way better LOP
I can only adjust 1 ECU at a time with my current boxes, I decided play with the timing of 1 ignition while on the ground for the lower RPM's. My airplane has always had a dead spot from 700RPM to 1000RPM when slowly applying throttle. I notice the dead spot when adding power to taxi from idle and when power is all the way back in the pattern and I need to add a smidge of power in the pattern. I always assumed that I wasn't moving the throttle fast/far enough to properly engage the accelerator pump of my carb. I played with the timing from 10-40* and found 750 RPM and up that 25* timing with the 7* manifold pressure advance (32* total) seems to give the smoothest running idle. The dead spot between 700-1000RPM seems to be gone. The timing advance increased my idle 200ish RPM and things were too hot to adjust it back to 500 and play with timing there.
TooBuilder has some good advice about playing with the timing "in situ." I plan on playing with timing on 1 ignition and recording values and tweaking as I go. Good news is I get to do a lot more flying, about that time and money......
If I find the best timing value for advanced timing with 1 ignition is there a ballpark change in timing that will occur when both ignitions are set to the same advance? For Example if my engine performs best at 25* on 1 ignition adding the second ignition should roughly change the value by how much?
RV 7 300 hours and counting
12/17 donation
Old 02-13-2018, 10:47 PM
Toobuilder's Avatar
The ballpark difference I experienced was 3 degrees between a magneto and the single CPI at "optimum". I'd expect you will see less than that
Michael Robinson
______________
RV-8 - Flying
Old 02-14-2018, 09:15 AM
DanH's Avatar
DanH DanH is offline
-better idle
Interesting.
Climb is with mixture parked on full rich, or leaning to maintain best power through the climb? What was climb RPM?
Is 21" your WOT manifold pressure at 7500?
I would expect the stock EFII schedule to be a little better LOP at 21" as compared to the 23+5 schedule, because timing is 28 vs 30. It's hard to imagine how the EFII schedule can be way better than the 25+5 schedule, as they're the same timing, 30 BTDC.
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-14-2018, 10:43 AM
Toobuilder's Avatar
In my opinion, ignore LOP performance until you have the capability to manually select that condition. Tuning an overall curve for LOP will always mean you are too advanced for best power mixture. The opposite is true of course. Best power timing will be too retarded for LOP. It's the fundamental flaw in the "one size fits all" approach to timing.
You can certainly play with the LOP advance as a knowledge exercise, but call Ross and get a reflash before you try to execute a new curve
Michael Robinson
______________
RV-8 - Flying
Old 02-14-2018, 12:54 PM
Interesting.
90 KIAS, leanest cylinder was leaned to 100ish ROP and climb RPM 2100ish. I never fly this configuration, just wanted to start somewhere. I need to do multiple climbouts at the different ignition advances, usually 130 KIAS.
Throttle was pulled back several inches, to even out EGT’s for LOP. My mixture distribution at full throttle is horrible, 150-200 degrees between richest and leanest cylinder.
The advance schedule I plugged in has 4* of advance at 21” MAP, 23* base gives 27* total advance and 25* base is 29* total. 20” MAP would’ve given me 30*. Splitting hairs for sure, but 7500 and 21-22” was a good setup LOP prior. As I think about it more, I left the mixture LOP for the descent and it was smooth all the way down. Below 18” MAP gave me 30* with a 23* base timng and 32* at 25* base timing.
12/17 donation
Old 02-14-2018, 01:07 PM
I agree the LOP switch is the best way to get the most out of ROP and LOP and the software flash is in my future. Meanwhile Iíve got a X/C trip this weekend which should give me lots of opportunity to play with timing in cruise at various power settings and altitudes.
12/17 donation
Old 02-14-2018, 02:49 PM
Toobuilder's Avatar
Sure. Cross country time is a good opportunity to play. Lots of time to let it really stabilize after an adjustment. Even with one ignition with the adjustment you should be able to get very close to your final number.
Michael Robinson
______________
RV-8 - Flying
Old 04-03-2018, 10:51 PM
So my 20 hours of flight time playing with timing using 23-25 BTDC for normal flight ops gave me consistenly lower CHT's on climbout, but inconclusive results overall with advance at lower manifold pressure settings. More on that later...
I removed my ECU's and sent them to Ross at SDS for a new software flash for the LOP switch functionality. While waiting for my ECU's I added 1 wire to each ECU connector joined at a switch to provide 12 volts for the LOP function.
I put a lot of thought into making the LOP switch fit my normal checklist/cockpit flow, I put the switch next to the fuel pump/throttle where it seemed to flow the best.
I'm lucky my local awards/trophy shop is easy to deal with, they were able to make a panel sticker for my new switch to match the other stickers.
If starting over I would probably place it right next to the mixture, but it does stand out a little bit and is next to the throttle/mixture. I had thought about putting the LOP switch by the ignition switches, but I tend to ignore that side of the switch quadrant as the master/ebus/alts/ignitions are always on, I think this spot ties it more to throttle/mixture settings as it should be.
I had never verified the timing pickup magnets in the flywheel, Robert from EFII had drilled and installed them on my original installation. Referencing the SDS instructions and Lycoming service instruction 1437, I needed to make a 10 degree mark on the back of the ring gear and make a pointer denoting the case split.
I used a cloth tape measure to measure halfway between TDC and 20 on the ring gear and made a mark. The Lycoming tool looks like it just squares off the ring gear so I did the same with my carpenters square and measured back to the case split and drew a line on my plenum and made a pointer from an old hacksaw blade.
I set up the timing light, chocked the airplane and it was almost easier than checking the timing on a car engine. Not sure why I never verified prior, but my position/ timing was correct. I verified by changing the magnet position programmed on the ECU's.
I input my RPM timing and manifold pressure retard/advance schedule and did a series of runups. I only have 1 programmer so I can only view/interact with 1 ignition on the fly. I tend to leave the programmer on my 88 ECU as it is wired to the battery bus and I don't have to turn anything else on to play with programming. Everything seemed well with the ignitions and a quick glance at the programmer showed my expected timing of 23 degrees (25 BTDC via RPM and 2 degrees of retard at 29 inches manifold pressure) upon full power for the takeoff roll. When I leveled off at 3000 AGL and pulled power I didn't see the expected advance as manifold pressure was reduced. My LOP switch did not apply the programmed 7 degrees of advance either.
Back on the ground I found my 71 ECU was performing as programmed, It was late Friday evening and I put it away sent a couple of emails and pondered the problem. A couple of days, a discussion with Ross and a little more trouble shooting found a bad manifold pressure sensor. My system has a separate manifold pressure sensor for each ECU, easy to swap sensors and verify the bad sensor. My manifold pressure sensor failed "high" as in it was always reading 30.1. I picked up a replacement at NAPA, it was a stock GM/ Delphi sensor.
Makes me wonder how long the sensor has been bad, I should have caught it as soon as I started using the programmer. I am a slow learner and learn by doing (making mistakes).... But I spent most my time in the RPM/manifold pressure setting windows and only more recently using the gauge pages of the programmer that show ignition timing/manifold pressure/RPM. Could've been dead from installation, with the proper timing curve its very hard to tell anything is amiss when the engine is happily purring along.
Why didn't my LOP switch work?
There is a hidden setup menu in the SDS ECU's, one of these settings voids the LOP switch above 25.1 inches manifold pressure. Nice little safety feature for sensor or Pilot failure.
I'm looking forward to more flying and hopefully more definitive results with my timing.
12/17 donation
Old 04-04-2018, 07:35 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Good write up and photos Andy.
For those not so familiar with the dual ECU, 4 cylinder setup, each ECU runs one set of spark plugs at all times but only one ECU is running the injectors at a time so if the backup ECU MAP sensor failed and is pulled high by the ECU (to allow the engine to make near full power), you would not notice any big running changes if you were running on the primary ECU.
Having the dual access programmer is a big plus with dual ECU as you can easily toggle between ECUs with the flip of a switch instead of unplugging cables and rebooting. Gauge 1 mode allows you to see MAP, RPM and the temp sensor outputs plus any sensor error codes for quick diagnostics.
It's important to verify initial timing with a timing gun as Andy shows here. Don't rely on base settings as many people have found these 2-4 degrees advanced over reality which can be dangerous, especially when operating on mogas. You can change the timing offsets by using the Magnet Position Window with your timing gun hooked up. This is a one time thing, once done, your total timing (rpm timing +/- MAP advance/ retard) will always be displayed correctly in the programmer.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 427.8 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
