Old 02-09-2018, 08:25 PM
Elbolador76 Elbolador76 is offline
Exclamation Engine size
Newby to this
I currently own an RV8A with an 0-320
I started doing basic aerobatics and love it.
Iím selling my RV8A to buy another RV8 TW with more horses and inverted system.
Van recommend engine size up to 0-360
What do you guys think or know about RVs with I0-390??
Would that affect any of the aerobatic maneuvers ??
Thanks in advance for the help.
Old 02-09-2018, 09:26 PM
RV6_flyer's Avatar
Originally Posted by Elbolador76 View Post
Newby to this
Dan Horton (DanH) has that setup. If he does not respond, contact him directly.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-09-2018, 11:33 PM
Thanks Gary, I will contact Danh
Old 02-09-2018, 11:50 PM
arffguy arffguy is offline
Default Another IO-390
Dan, aka "flynwest" has one as well.
Look for his posts.
Mike F
RV-6A wings/fuselage
RV-3 empennage (extra thanks to Mr. Zilik)
RV-4 Plans only S/N 2938
Cessna 152
Elk Grove, CA
VAF #744 Exempt but paid in Feb anyway
Old 02-10-2018, 01:12 AM
Capt Capt is offline
Most 8's seems to have a 360/180 ponies, injected is an advantage as well as C/S, it's all about the green back as you Yanks say!
Old 02-10-2018, 08:24 AM
Carl Froehlich's Avatar
Recommend you talk to Mitch Lock at Vanís. He shares my thoughts on the parallel valve IO-360 (180hp) and Hartzell CS prop as a sweet spot for this airplane.
But - if your performance target is first plane to 10kí regardless of fuel burn and cost, the IO-390 is a better match. For effiecent cross country and maneuvering the 180hp engine and CS prop is, in my opinion, the right set up.
Old 02-10-2018, 09:32 AM
Look for his posts.
Thanks Arffguy, I will look for Dan Flynwest posts
Old 02-10-2018, 09:35 AM
Talking
That seems to be a very popular setup
I hope I can find one with all of that for the right amount of mula.
Old 02-10-2018, 09:40 AM
Originally Posted by Carl Froehlich View Post
Recommend you talk to Mitch Lock at Van’s. He shares my thoughts on the parallel valve IO-360 (180hp) and Hartzell CS prop as a sweet spot for this airplane.
But - if your performance target is first plane to 10k’ regardless of fuel burn and cost, the IO-390 is a better match. For effiecent cross country and maneuvering the 180hp engine and CS prop is, in my opinion, the right set up.
Thanks Carl
I love doing recreational aerobatics and
I think the 180hp with C/S prop is making more sense.
Old 02-10-2018, 09:46 AM
Talking
Thanks Capt
Yes thats a popular setup with the 180hp and cs prop, Iím going to start searching for that setup, Iím hoping to find one with inverted system in it already.
