Old 02-06-2018, 07:32 AM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default Fuel tank vent B nut leaking.
Is there a way to tighten the fuel vent B-nut on the inside of the tank without major surgery? My right wing perpetually drips fuel out of the vent when the tank is filled to over 25 gallons.
We bought the quick build option specifically so we wouldn't have these issues. I recently had to remove the left wing tank and send it back to Vans because it was leaking like a sieve in multiple locations, and I do not want to repeat that exercise if I don't have to.
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
Old 02-06-2018, 10:46 AM
Breezy Breezy is offline
Jack & Dave,
There is no way to tighten the internal "B" nut for the tank vent without removing the access plate at the root end of the tank.
If it is any consolation you are not alone with this. I have seen three aircraft with this exact issue. All were QB kits.
Removing the tanks is not as difficult as it may seem. In a day you can have them back on. The down time is waiting for the sealant to cure.
Breezy
First offense RV-8; N594WR; 80594 (time served)
ECI TITAN IOX 360 A1A9N, G3X
Repeat Offender: 83137 (Flying 10/16)
N837DW; Superior IO 360; G3X Touch.
Exceptional Aircraft Award, Sun N Fun 2017; Best Homebuilt, Mid-Eastern Regional Fly-in 2017.
One More Time: 140359, -14 in process, IO-390 (Maybe)
KHAO (Hogan Field)
Old 02-06-2018, 02:29 PM
bpattonsoa bpattonsoa is offline
You bet there is a thread. In the -10 forum search for vent leak. Not an uncommon problem with QB wings. If you are not yet painted I would consider removing the tank and going in from the back after getting a repair kit and Proseal from Vans. I discuss how to make it Ok to fly and stop it on the ground in a post.
Have fun!
Bruce Patton
Building Rans S-20 Raven 796S reserved
Going to the light side!
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S tail, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum, interior complete. 1624 lbs, FLYING after a 21.5 month build.
Old 02-06-2018, 02:32 PM
mdaniell mdaniell is offline
I had the exact same problem with my QB tanks. There are some previous threads on the same topic which you may have seen. You can get limited access by removing the sender plate and adapting a spanner. There is limited clearance between the nut and the top of the tank for a normal ring spanner.
See: http://www.vansairforce.com/communit...ighlight=b-nut
Martin
Old 02-06-2018, 02:46 PM
Martin
Sorry, I meant a ring spanner modified to with a slot to get over the tube.
Old 02-06-2018, 11:54 PM
Jake14 Jake14 is offline
In my case tightening wouldn't have helped..the problem was a bad (cracked) flare on the line.. thread here:
http://www.vansairforce.com/communit...highlight=vent
RV-14A #140158 flying
Old 02-07-2018, 11:09 AM
Machsandy Machsandy is offline
We just cured a leak using advice from the previous threads. The tightening solved our problem but ours is not QB. What we did slightly differently was made 2 x tools using 2 x sockets with a slot and a 90 degree handle on each. By calculation we thought we could get about 20 degrees of movement on each turn through the fuel tank sender hole. As a socket has 12 points so would need 30 degrees of movement to go to the next point, we made up 2 x tools with a 15 degree offset between each tool and then alternated each tool every turn.
You are very welcome to borrow the tools but they are in the UK!
Old 02-07-2018, 07:01 PM
togaflyer togaflyer is offline
I checked mine, based on previous posts, before installing the sender unit. One was tight, the other I got a good 1/2 turn. I used a stubby wrench with an open end/closed end. I used a long piece of safety wire twisted to the closed end of the wrench and slipped the open end over the b nut, pulling on the safety wire to tighten the nut. I had a bore scope to watch what I was doing. I dont think its possible without pulling the wing and removing the sender.
Old 02-08-2018, 05:55 AM
We did our repair on the wing. So we removed the wing root fairing and the fuel sender only
