Old 02-05-2018, 11:41 PM
atalla atalla is offline
Default how do i rivet the elevator root?
Hey guys,
I messed up 4 of 4 here
https://youtu.be/BGj_2nSDEs8
11:30
does anyone have any tips?
Should i make a special bucking bar?
Andrew Atalla
Red Seal Automotive Service Technician
Red Seal Heavy Duty Equipment Service Technician
Whistler BC
RV-7 Left Elevator in progress.
2018 Dues paid
Old 02-06-2018, 12:01 AM
Bevan Bevan is offline
I only watched a small portion of your video. If you could post a simple picture or tell us a time stamp to go to on the video that may help us help you.
Off hand I don’t recall any difficulty riveting the elevator root.
Bevan
Abbotsford BC
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 02-06-2018, 12:09 AM
Where the stiffeners meet the root of the elevator. Should I just open up the flap?
Andrew Atalla
Whistler BC
2018 Dues paid
Old 02-06-2018, 06:36 AM
pa38112 pa38112 is offline
It looks like you are asking about the first couple of rivets at the leading edge? Yes, you open the fold. It feels like you are un-bending it, but it will go right back. I would use a straight shank, not that offset one. It helps to have someone hold the piece down and open while you rivet.
http://aprs.fi/N153MC
2004 RV6A Flying
Old 02-06-2018, 08:49 AM
Tag Tag is offline
Default Backriveting Trailing Edge
Yes, you can open the "flap" enough to do standard backriveting. I just used my head (physically!) and did it myself but it may help to have an assistant. As you are aware, use caution to prevent the bottom piece from lifting off of the backrivetting plate, which it will want to do...
I also used a longer, straight backriveting set.
One more tip: try using standard, "Scotch" tape, even less expense than the Blue tape!
Nice videos!
Old 02-06-2018, 02:15 PM
ok awesome guys thanks, i was worried about bending the elevator open too much. ill drill those out and get someone to give me a hand.
Andrew Atalla
Whistler BC
2018 Dues paid
Old 02-06-2018, 06:17 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Couple of tips
Small grommet from HD or Lowes when looking at it from the sides looks lie 2 U shapes back to back has enough squish to go around rivet and force the parts together while you are riveting, if sections don't want to stay togetheror they are stubborn. Also I think I saw someone say take "fuel Line" for model airplanes and cut them into slices. That works same way.
To hold open pieces if you don't have extra hands you can take some light string and run through a couple of rivet holes and tie it off to hold pieces open.
Pete
RV14A Tail kit build in process
RV 14 WIKI in process, residing on Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 2018 (Military exempt) Cause its worth it.
Old 02-06-2018, 06:42 PM
wirejock's Avatar
wirejock wirejock is offline
Default Elevator
I use the small windshield washer rubber hose. Slice off a doughnut. Lasts for several rivets.
When you open the elevator skin, find a way to keep it open till you're done. Don't flex back and forth any more than necessary.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-07-2018, 08:26 PM
Originally Posted by HAL Pilot View Post
Couple of tips
OMG the fuel line trick is a great idea! Thank you both! This is why I chose Vans!
Andrew Atalla
Whistler BC
2018 Dues paid
Old 02-07-2018, 08:36 PM
Dbro172's Avatar
Dbro172 Dbro172 is online now
You dont need a helper, just push that skin back and get your rivet gun in there, dont kink the skin. For those overdriven rivets the hole is probably bored out too big now for an AN3, if you drill out the rivet you might need to open up the hole larger now for an “oops rivet”. (AN4 shank with and AN3 head)
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
www.mykitlog.com/dbro172/
1968 Mooney M20C - Sold
1956 C-182 - Sold
