Old 02-04-2018, 11:11 PM
iamtheari iamtheari is offline
Default Page 07-07 step 7
This step calls for dimpling numerous parts of the rudder, which are listed as:
R-00901-L-1 and R-00901-R-1 skins
R-00915 stiffeners
R-00902-1 spar
R-903
R-912
R-00915-1 ribs
R-00918 attach strips
R-00910 horn brace
I believe that the reference to R-00915-1 ribs should be to R-00904A-1 and R-00904B-1 bottom ribs. I canít find any R-00915-1 parts except for the stiffeners and it seems that the bottom ribs do need to be dimpled.
But I am calling it quits for the night and hoping someone will confirm or clear up my thoughts before I put any dimples in the bottom ribs. Thanks in advance!
Old 02-05-2018, 01:31 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Hi Ari
You end up dimpling most of the rudder skins except towards the top. Go to the link in my signature see page 79 of the PDF. There's multiple comment's. also use the hyperlink at step 7 to quickly jump between pg 07-12 and 07-07.
Hope that helps.
Pete
RV14A Tail kit build in process
RV 14 WIKI in process, residing on Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 2018 (Military exempt) Cause its worth it.
Old 02-05-2018, 02:28 PM
Originally Posted by HAL Pilot View Post
Hi Ari
Hope that helps.
The "wiki" PDF doesn't seem to have a direct answer to this issue with the plans. It's also not clear what it means by the comment "You will end up with only 5 holes to rivet" which is right below Step 7. There isn't any obvious group of 5 holes to rivet except on the forward edge of the skins, where they are riveted on top of each other and to the tip rib and counterweight rib.
My question is on the R-00904 bottom ribs. There is a thread that is linked to on page 07-10 in the PDF, with this comment:
"Dimple R-904 pieces.... NOTE Not sure this is an issue anymore. PF." That thread from March, 2014 (http://www.vansairforce.com/communit...d.php?t=110873) was asking about page 07-08 but it is definitely the same question I have. Unfortunately, it has no replies.
I've e-mailed Van's to ask about the apparent error in referring to the R-00915-1 Ribs instead of the R-00904 Bottom Ribs. I'll post back here if and when I get an answer.
Old 02-05-2018, 03:24 PM
HAL Pilot's Avatar
Basically every hole in the skin that has AN426AD3-xx rivets gets dimpled except for the ones that say do not dimple. so every piece under gets gets a corresponding dimple.
Hope that helps
Pete
EAA 1300
Old 02-05-2018, 03:40 PM
Hope that helps
Yes, it helps. It confirms that I'm right and the plans are wrong.
Old 02-05-2018, 04:58 PM
Van's got back to me just now and confirmed that this is a misprint. The instruction should refer to dimpling the R-00904 bottom ribs.
Old 02-06-2018, 02:34 PM
OrenAir OrenAir is offline
Talking
The plans for the most part are pretty good. In some places not so great. Overall they're at least okay in my opinion. I recommend reading far ahead before doing much work.
Here's one example:
Page 10-11 step 7: prime the F-1037B and F-1037C battery angles as desired.
Page 10-12 step 4: prime the F-1037B and F-1037C battery angles as desired.
Ok, so two coats, or is the second in case I decided against priming, then changed my mind on the next page? :-)
Read slowly, think about what you're doing, and good luck.
Old 02-06-2018, 03:13 PM
Here's one example:
Thanks for pointing out an error that hadn't been noted previously.
With some thing as complicated and sequence sensitive as building an RV-14,
there is bound to be an error occasionally (but they are slowly getting corrected as builders point them out)
Very few have been issues that would prevent someone that is thinking about what they are doing, from getting a correct result (as in this example).
Read slowly and think is very good advice when building something of this complexity, and I think the prelim sections of the plans recommend reading through an entire section before beginning, to gain some situational awareness of what is coming.
Scott McDaniels
Hubbard, Oregon
Old 08-05-2018, 03:57 PM
markelliott markelliott is offline
Interesting that you posted this in Feb 2018 - I received my kit in July and have come across this misprint. Van's still hasn't fixed it but thanks to VAF I have my answer on a Sunday! I just wanted to say "Thanks" for posting your findings - it saves many of us time.
Old 08-19-2018, 06:39 AM
Yank Yank is offline
Perfect timing.....Just got to this step a few days ago and remembered this post....
Spotsylvania, VA
RV-14 Tail kit in progress
