Old 01-31-2018, 07:08 PM
JDA_BTR JDA_BTR is offline
Default Hole below the rudder cable guide in the tunnel?
Where the rudder cables enter the cabin by your feet in the tunnel there is a hole just below that doesn’t seem to have a use. I was considering using it for a wiring Adel in the tunnel but maybe it has a different purpose not yet revealed?
What’s it for?
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 01-31-2018, 09:23 PM
Jake14 Jake14 is offline
I used it for an adel clamp...both sides
RV-14A #140158 flying
Old 02-01-2018, 07:16 AM
Jesse's Avatar
Jesse Jesse is offline
It should be for an ASEL clamp holding the plastic rudder Cable sleeve in place so the Cable doesn’t rub on the tunnel side.
352-427-0285
jesse@saintaviation.com
Old 02-01-2018, 09:29 AM
The RV-14 uses machined UHMW cable guides mounted in the side panel of the tunnel.
The holes mentioned are intended for clamps to support any systems cables/wires at the mid point of the tunnel.
Scott McDaniels
Hubbard, Oregon
Old 02-01-2018, 11:10 AM
Perfect! I had put nutplates in the unused outboard positions of the fuel pump bracket but putting clamps on the tunnel side will be far superior.
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
