Old 01-31-2018, 01:22 PM
bob888 bob888 is offline
Default Cleaning engine after messy oil filter change
Anyone have a good method for cleaning up the engine?
Old 01-31-2018, 01:40 PM
DGlaeser DGlaeser is offline
Spray it down with Mineral spirits.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport & EIS4000, 300XL, SL30, ADI Pilot II, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 01-31-2018, 06:40 PM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
Brush on automotive engine degreaser. Non flammable. Rinse off with hose.
Old 01-31-2018, 07:36 PM
snopercod's Avatar
It might be wrong, but I use non-cholorinated brake cleaner.
(2018 dues paid)
Old 01-31-2018, 07:59 PM
VA Maule VA Maule is offline
Default Break cleaner
I don't think you're wrong I've been using it for many years on all types of applications from bulldozers to motorcycles, Corvettes to airplanes with no harm to anything. BUT NOT THE CANOPY!! Everything seems to harm that piece of clear plastic.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 01-31-2018, 08:49 PM
A friend gave me an oil filter adapter that positions the filter to come off down so oil will not drip out. I'm sure I will make a mess but at least I have a chance!
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 01-31-2018, 08:52 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Not an answer to your question asked but an option so that you don’t need to ask the question in the future...
form-a-funnels are the cats meow when it comes to getting the filter off without making a mess. Nothing really worked until I tried it.
https://www.amazon.com/Form-Funnel-F...%2Bfunnel&th=1
Hope this helps.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2019
Old 01-31-2018, 09:36 PM
Jake14 Jake14 is offline
Again, not an answer, but I've had good luck with (after loosening filter to finger tight) putting a plastic bag over the filter and fastening it just ahead of the filter with a zip-tie. Then tear a hole in the bag and unscrew the filter. The oil should run down into the (heavy duty) plastic bag, then you can drop the filter in there as well and cut the zip-tie.
RV-14A #140158 flying
Old 02-01-2018, 06:13 AM
Jasonm Jasonm is offline
Default Simple Green
I tried this on the belly and was really impressed on how well it works. Could be used elsewhere too.
http://www.aircraftspruce.com/catalo...?clickkey=9276
Jason McKay
"Phase 1 - 05/26 - 07/02"
2017 Dues Paid
Old 02-01-2018, 06:23 AM
Mark Dickens's Avatar
After landing from a flight, so the oil is hot, I simply level the plane (tail dragger), start draining the oil, and punch a small hole in the filter so that the oil drains out of the filter. I go home for the evening, and I come back, the filter is empty and all I have to do is wipe up a drop or two. Of course this assumes that the filter is at an angle so that it will drain.
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
