Old 01-27-2018, 08:31 PM
togaflyer togaflyer is offline
Default G3X auto pilot servo settings
Looking for the gain and torque settings for the Garmin servos that have worked well for you. Thanks!
Old 01-29-2018, 08:21 AM
rdrcrmatt rdrcrmatt is offline
I had an issue with the AP overshooting headings by quite a bit. Garmin suggested I try the following.
75% torque / .8 gain on ROLL
79% torque / 1.3 gain for Pitch
I wish I would have documented the before setting. It's better now, but still overshoots a little.
Matt
2018 Dues Paid.
Old 01-29-2018, 08:27 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello,
Just a reminder that Appendix A of the Rev. AD G3X/G3X Touch Installation Manual is called FLIGHT TEST PLAN FOR AUTOPILOT TUNING and includes pretty comprehensive autopilot tuning instructions for anyone wanting to make improvements to the default settings.
Let us know if you have questions.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 01-29-2018, 09:05 AM
868RM 868RM is online now
Default Setting
I needed to make very small changes and wait at least a minute before next change.It is very easy to go right past the best setting.
Old 01-31-2018, 09:51 PM
I noticed that on the Van’s WEB site for the RV 14, they have recommended setting for the Garmin Auto Pilot system. I wonder how much difference between the -14 and the -10 would be with the same settings.
Old 02-01-2018, 05:22 PM
Dorfie Dorfie is offline
Togaflyer,
Here are the settings I started out on and mostly still the same.
ROLL SERVO:
Gain 0.8
Max Torque 100%
Fine adjust amount 0.0
Fine adjust time 0.2 ( I think this was not available on my G3X system but not sure. Will have to check)
PITCH SERVO:
Max torque 100%
Gain 2.5
Fine adjust amount 1.0
PITCH GAIN:
Min AS 70Kts
Max AS 180Kts
Vert speed gain 1.4
Vert accel gain 1.0
Airspeed gain 1.35
Airspeed accel gain 1.0
I have reduced the Pitch servo gain over time to smooth altitude hold from 2.5 to (from memory) around 1.8. The servo pitch changes were too abrupt in level flight to my liking.
I occasionally have a little hunting in HDG and NAV mode. I have not been able to correct that. It only happens once in a while and usually on longer flights. When it does this it will overshoot the initial set heading by about 5 degrees, turn back on correct heading fairly quickly. It will then slowly rock the wings while not noticeably going off heading. Maybe someone can help me with this issue.
Hope this helps.
Johan
Dorfie
RV10
2018 dues paid with a smile
Dorfie
RV10 Flying, N245JM
Old 02-02-2018, 02:27 PM
rcoleman-10 rcoleman-10 is offline
Johan, I have the same HDG hunting problem. Happens on long flights, turbulence, or steady cross wind......can't seem to lock it in...I hope we can find more input on how to solve.
Ron
Austin, Tx
