Old 01-26-2018, 03:41 PM
Mikeandmaz Mikeandmaz is offline
Default Rudder spar bent?
Hi All,
Iím very new to the RV build world and am starting the Rudder build. Iíve noticed that the Spar is slightly bent. Itís measuring 3/32Ē off the work bench at one end when lying flat. Is this an allowable amount or do I need to try to straighten it somehow? I know the thicker pieces can arrive bent, ive straightened the VS Doubler but what about the Rudder Spar?
Mike
Empennage arrived
VS completed
Rudder completed
HS completed
Elevators in progress
#140425
Donation paid 2018
Old 01-26-2018, 04:30 PM
Aluminum Aluminum is offline
Originally Posted by Mikeandmaz View Post
Hi All,
Mike
You will find it necessary to "encourage" most of the long parts to align with the hole patterns, as the forming/punching/bending process builds in some stress that tends to curve. The preload from this is negligible compared to the design loads on the structure in flight. Do not try to straighten the spar before riveting, you're more likely to crinkle than improve (a more extreme example of this will be the fluting of ribs once you get to that point). The manual will state clearly which parts need straightening, e.g. HS attach brackets; the VS doubler didn't, but it doesn't hurt now that you've done it.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2018 dues worth every penny
Old 01-26-2018, 09:04 PM
Mudfly Mudfly is offline
Hey Mike,
Welcome to the RV world. Sounds like your very particular..and that's a good thing when you're building an airplane in you garage. After some time, you'll get a better feel for when something isn't right and know when to "make the call" to HQ in Oregon. I think one of the most difficult things for me initially was not knowing when the materials, or my work wasn't acceptable. I started with high expectations thinking I would build the perfect airplane. Over time, that goal has changed to building a SAFE airplane.
Regarding your rudder spar...I think it's ok. Just for a test though. Try clecoing the rudder skins to the spar. The clecos have a little more slop/tolerance than the rivets, but it will give you a idea of what you're dealing with.
Good luck and enjoy the experience!
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2019 VAF Donation Complete
Old 01-26-2018, 10:26 PM
kiljoy's Avatar
kiljoy kiljoy is offline
Welcome Mike,
Just wait until you start working with J-channel material and dimple it. It puts the a bow on the J-channel. You don't think it'd ever fit but it gently bends back to straight.
Dues paid (2019)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - Crating late Jan. 2019
YouTube Build Channel
Old 01-27-2018, 01:14 AM
Thanks for the replies. I’m aware that one of my many failings is to think I can just carry on and wing it and it will be alright! I’m trying to be a bit more particular with the build, I guess maybe a bit too much, that’s a relief!
Looking forward to the “journey!”
Empennage arrived
VS completed
Rudder completed
HS completed
#140425
Donation paid 2018
Old 01-27-2018, 04:37 AM
paul330 paul330 is offline
Just make sure you clamp everything tight before you rivet or there will be gaps between the spar and the angles. Spring-loaded clamps won't do it......
Paul
Mercy Air, White River FAWV
ZU-IIZ - "Zeus"
2018 Donation Made
