Old 01-25-2018, 09:53 PM
DHeal DHeal is offline
Default Setting Cherry Max Rivets
FYI -- A new video from Van's regarding the setting of Cherry Max rivets at:
https://www.youtube.com/watch?v=lb9miRllZDo
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 600+ hours (as of Feb 2018)!
VAF donation through June 2018.
Old 01-25-2018, 11:52 PM
rv9builder rv9builder is offline
Thanks for posting the link, David! Looks like a great tip. Is there a place on Van's website where videos like this are posted?
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
Old 01-26-2018, 04:34 AM
mike newall's Avatar
They have a channel
https://www.youtube.com/channel/UCLY...j1kbl33Z5NOshg
Donated twice in 2017
Old 01-26-2018, 03:20 PM
Originally Posted by mike newall View Post
Thanks, Mike!
RV-12iS Fuselage
RV-9A Project: Sold
Old 01-31-2018, 06:40 PM
philcam's Avatar
philcam philcam is offline
Anyone else at this stage yet? Iím having horrible luck with theses rivets even following the video, only about 1 in 3 rivets are acceptable.
Phil Campbell
VAF # 1043
Builder # 82699
RV-8 Builder, ex-Grumman AA1B owner
DFW Metromess
Old 01-31-2018, 06:47 PM
Walt's Avatar
Walt Walt is offline
It helps to use a cherry max puller, standard pop rivet pullers don't work very well on CM.
http://www.aircraftspruce.com/catalo...php?recfer=505
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 02-01-2018, 08:22 PM
rolick22's Avatar
rolick22 rolick22 is offline
Having a lot of trouble too, even using a cherry max hand puller. I tried the Van way of lubing the stem but no joy. Have had to order more. Thinking of going to find a pneumatic cherry max puller.
_____________________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
Finishing Kit on Hold
iS Fuselage In work
1st GEN FUSELAGE FOR SALE
Serial#12-0864
N864DR Reserved
Old 02-01-2018, 08:36 PM
Just as a reminder, the Cherry Max rivets look different from standard pull-rivets after installation. See Van's Chapter 5 - Page 05-07 for photos of Cherry Max rivets at: http://www.vansaircraft.com/pdf/revisions/RV-ALL_05.pdf
I know it took me awhile to adjust to the appearance of the shop end of a successfully pulled Cherry Max rivet.
Old 02-02-2018, 07:31 AM
rvsxer rvsxer is offline
Here is a good explanation of how CherryMax Rivets work, and what happens when one is properly set. http://www.cherryaerospace.com/docs/...gs/CA-1011.pdf
Before the CherryMax blind rivet was introduced, The CherryLock rivet was the structural blind rivet of choice. The main drawback to the CherryLock rivet was the requirement for a specialized, expensive puller that would set the mandrel lock ring during the pulling process. This lock ring is important as it positively locks the mandrel in place and allows the rivet to develop design strength. The CherryMax rivet uses a washer ("anvil") to set the lock ring, so a standard "pop rivet" puller can usually be used to set them. This is one reason why CherryMax rivets are approved on Standard Category aircraft size-for-size with solid rivets.
To easily remove a CherryMax rivet, the lock ring should be ground away, with a pencil grinder or a high-speed grinder and cutoff wheel. The (usually steel) mandrel can be driven out and the rivet head drilled as with a solid rivet.
Mike Hilger
RV-6 N207AM w/G3X, 1,400 hours +
South St. Paul, MN (KSGS)
Senior Tech - Panel Design, SteinAir, Inc.
A&P, EAA Tech Counselor
We're all here because we're not all there...
