Old 01-24-2018, 06:43 PM
Eztroller Eztroller is offline
Default Rudder
Super UNHAPPY with the final rudder product... The picture shows a large gap (several of them) that will need to be correct. Any ideas on how to fix.
https://photos.app.goo.gl/P3W3ftHYifBVtNLo1
Old 01-24-2018, 07:52 PM
bruceh's Avatar
bruceh bruceh is offline
You could use an edge forming tool to put a slight break in the skin that overlaps. The Cleaveland Edge Forming Tool works great for this.
See their demo video here.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 01-24-2018, 09:03 PM
azflyer21 azflyer21 is offline
Bruce is right. If you see page 7-12, step #2 it calls for you to put a slight bend in the leading edge of the left skin.
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N1402 reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 01-24-2018, 10:37 PM
Jake14 Jake14 is offline
I had a few gaps in my rudder LE. I drilled out the rivets and did some re-forming to remove the springback which causes the gaps. In a few places I added a rivet between the existing ones and also put an aluminum washer on the inside of the rivets (similar to those used on the baffles) to cinch things up better
RV-14A #140158 flying
