Old 01-18-2018, 03:42 PM
Eztroller Eztroller is offline
Default Flange straightening-with the tool
Do you straighten every rib flange?
Old 01-18-2018, 03:45 PM
Yes, I do.
RV-3B, now skinning the fuselage
Old 01-18-2018, 06:08 PM
Driving '67 Driving '67 is offline
Try setting up an assembly line ... things move quicker and I found I got more consistent results.
Great jig (plans found on VAF) for flanges
Quick double check to make sure everything is square.
RV 14A wing/tail/fuselage done
Doing the avionics/wiring harnesses
G3X/GTN650/GTN625/GTX45R
Waiting for warm weather to do the canopy
Serial 140118
Old 01-18-2018, 08:52 PM
wjb's Avatar
wjb wjb is offline
Every flange! The straightening tool is a godsend. It was the first tool I made!
The picture above is about all you need to build your own. My block, opposite the working end of the arm, was cut back 10 degrees to allow for springback. The resulting flanges came out at a nice 90-deg angle.
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Engine is in the house!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
Old 01-18-2018, 09:09 PM
Thx for the help. I have the tool and set it up as per another blog on here...11 degrees. I like the square idea and will start using that to check if im off or not. I would rather spend a lot of time getting this part right.
