Old 01-18-2018, 08:29 AM
N329JR's Avatar
N329JR N329JR is offline
Default Wing upper skin(s) trailing edge turned up at rear spar
I believe that I have seen a post or two on this issue previously.
I have riveted the the upper skins on recently and see that the skins trailing edge at the rear spar is turned up some amount.
I am wondering if all builders are running into this issue and are dealing with it by making a slotted bending block and bending the skin/rear spar flange combination back down flush.
Thanks for any input.
Ian
RV-3B My RV
RV-6 (Dad's RV)
RV-8 Empennage 95%, Wings 95%, Fuse 2%
2019 VAF Gladly Paid
Old 01-18-2018, 09:00 AM
fl-mike's Avatar
fl-mike fl-mike is offline
The infamous "ski-jump".
Vans has a tool you can borrow to fix this. Works well.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage in progress.
Old 01-18-2018, 09:32 AM
N329JR's Avatar
I see that "Ski Jump" is the key search phrase for this issue.
Thanks.
RV-3B My RV
RV-6 (Dad's RV)
Old 01-18-2018, 09:58 PM
fl-mike's Avatar
here's the Van's tool and a before and after. Use scraps of aluminum to protect the skin (like in the second picture), rear spar rivets, and spar flange or you'll gouge them when you do the bend.
before and after:
Mike W
Venice, FL
N164WM
Old 01-18-2018, 10:23 PM
wjb's Avatar
wjb wjb is offline
I borrowed one from Mike Cencula here on VAF -- it worked great!
See below for photos:
http://www.mykitlog.com/users/displa...g=218568&row=9
http://www.mykitlog.com/users/displa...g=242664&row=2
Bill Bencze
N430WB RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
