Old 01-17-2018, 04:31 PM
bkervaski's Avatar
Default Garmin Ammeter Shunt .. where to mount?
G3X Touch folks .. where are you guys installing your Ammeter Shunt?
Progress: Flying!
Old 01-17-2018, 05:11 PM
Nova RV Nova RV is offline
Under battery. Seemed like a good place in between the alternator and the pass through for the wire without needing any crazy bends or turns. Remember you need 1amp fuses in each leg off the shunt to the G3X.
Chris Moon
Leesburg, VA
RV-14A kit # 140243 (flying as of 11/18)
VAF 2018 and 2019 paid
www.mykitlog.com/chrismoon/
Old 01-17-2018, 06:40 PM
bkervaski's Avatar
Hmm.. what are you guys using for this? Just in-line fuses?
Progress: Flying!
Old 01-17-2018, 07:05 PM
JDA_BTR JDA_BTR is offline
Fusible link for me.... 20AWG for the signal wire with a 1-2" length of 24AWG at the shunt end. Reminds me I need to source some fiberglass sleeve....
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 01-17-2018, 07:19 PM
Thermos's Avatar
Thermos Thermos is offline
+1, right next to the 60a ANL fuse.
HTH,
Dave Setser
RV-7 skin, bones, muscle and heart complete, nervous system in progress
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
Old 01-18-2018, 08:22 AM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Default Here's my setup
Here's my setup. Garmin G3X shunt and ANL fuse. I used 24ga wire to make fuseable links.
Jared Solomon
A&P, EAA Technical Counselor
www.othaviation.com
Powder Springs, GA
2018 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
Old 01-18-2018, 08:23 AM
bkervaski's Avatar
@Jared_Solomon clean .. I like it! Thanks.
Progress: Flying!
Old 01-18-2018, 08:28 AM
Someone posted a link to small 1 amp fuses for electronics use, I think I got some from Digikey, they look like tiny resistors. I'm not using an ANL but a 60 amp CB in the cabin.
Digikey PN F2313-ND
Chris Moon
Leesburg, VA
Old 01-18-2018, 12:46 PM
n982sx n982sx is online now
I have two shunts and current limiters since I have added a second alternator and power bus.
My primary shunt/limiter set up looks almost identical to Jared's post above.
I'm posting this image of my second shunt/limiter to show the fusible links I used instead of inline or panel mounted fuses. I had a bunch on hand left over from my first aircraft build. One amp inline fuses would work just as well.
The second set of contactors are for a ground power bus and to crossfeed my two power buses together. All straight out of the Aeroelectric book.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
