Old 01-17-2018, 10:55 AM
JDA_BTR JDA_BTR is offline
Default Firewall Shunt/ANL Attachment
I'm going to place the shunt and ANL adapter next to the battery contactor on the left firewall. What is best practice hardware to use, and is a doubler necessary?
Ser 104142, RV-14A
N1463
Final Assembly....
Old 01-18-2018, 08:32 AM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Default What I used
In both planes that I've built, I did not put a backer plate in. I've never had a any problems. Most would say a backer plate is a "best practice" though. As far as hardware, I used stainless steel screws and lock-nuts (1/4 inch if I recall), 1-1/2" long. The counter sink in most ANL fuseholder is 82 degrees. If you end up going with a backer plate you can use nutplates instead of lock-nuts, just make sure the the screws are fine thread (1/4-28). A link below to an example of screws that should work:
https://www.boltdepot.com/Product-De...x?product=9794
Jared Solomon
A&P, EAA Technical Counselor
www.othaviation.com
Powder Springs, GA
2018 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
